3rd GEN TL ON DRAG STRIP w/ AEM CAI
Feenin on some 20's
OK guys. i just got bak from the track - Sacramento Raceway...
My Dial-in was 14.90 . . .
Fastest I ran was a 15.060@ 95.365...
Reaction: .430
Temp: 90 Deg.
Once Again, This is with Stock Tires, removed spare tire, and AEM CAI...
O yea, btw, Saw a 2.5RL and a 2.2//3.0 CL... Anybody from acurazine???
Here's the time slip.
here are my times, tell me what you guys think.. has anybody done faster in a AUTO TL??? please let me know.. it was HOT.. I'm sure with better tires and better weather, i can hit that 14.9 i was dialed in for.
Reaction: .430
Temp: 90 Deg.
Originally Posted by 01clsstock
wow ... that seems like a pretty crappy time.
If you could get that 60 ft down to the 2.1 range, which is reasonable for a FWD car, you'd be in the 14.4-14.6 range, which is very respectable for an auto.
Work on the launch and get back to us!
Feenin on some 20's
there is no way i can get down to that 14.4-14.6 range with stock tires and that weather.. Track was also poorly prepped. maybe on slicks i can do somwhere like 14.8? Witht he stockies, no way..
01clsstock - you find someone with a stock auto time way better than my 'crappy' time and then talk.
friskoplayer - when u planning on going?
Feenin on some 20's
My best 60' was 2.398... I don't understand how i can do better man.. Can anyone show that their 04-06 A/T TL can get a lower 60'?? I would love to see that...
ALSO, from 1st to 2nd gear, the TL shifts by itself, like 300-400 before redline//rev limiter...
You'll Never Walk Alone
From my understanding, the best way to launch is to use the brake torquing technique. Rev up to around 2000rpm while in gear, holding the car still, quickly release the brake pedal and apply more throttle (around 3/4 of the way) for a split sec, then floor it. If you do this correctly, you will launch a lot faster and get a good 60ft time.
Feenin on some 20's
Originally Posted by JJaber06
Launch in "L", it holds 1st and 2nd to redline, then shift to SS mode after 2nd gear is done
hmm..that's interesting, try putting it in 1st gear (as in slide your gear shifter all the way to "1"), apply enough throttle so that it will rev to 7000rpm, you should travelling at around 70km/h (44mph?), see if it will upshift automatically even though you have your gear shifter in "1." From my experience, the car should just be bouncing at the rev limit (~7200rpm) instead of upshifting automatically.
Feenin on some 20's
I have a 3rd gen TL. it only has a "L", no 1 like the 2nd Gen TL's do..
lanechanger
10-13-2015 10:56 AM
