3rd gear grind?
Old Sep 23, 2006 | 10:38 AM
FlyingPig's Avatar
3rd gear grind?
I know I'm sucking real bad.
I have been grinding that 3rd gear. For the life of me, I just can't get into that 3rd gear!!
I either can't get in there, so it grinds when I get in.
I guess my short arm is just spoiled.....this stick just seems to travel so far.
Old Sep 23, 2006 | 10:54 AM
Spiritman's Avatar
Man of God.....
Try what other have. Short trow shifter/one of the top synth lub's in your tranny. Look around / search. Its all here my friend.....
Old Sep 23, 2006 | 02:09 PM
ubnpast's Avatar
time to get an auto. is this your first manual car?
Old Sep 23, 2006 | 02:29 PM
trancemission's Avatar
Regions Leader
This may not totally be your fault. Go to problems and fixes and do a search for the 3rd gear issues we are having. I would look for you but I just dont have time atm....
Old Sep 23, 2006 | 04:17 PM
Midnight_TL's Avatar
yea just recently i've noticed that on rare occassions i'll shift to 3rd and then it'll grind then pop out. it's good most of the time, so i make sure i shift hard into 3rd. hasn't been a problem for about a month now...
Old Sep 23, 2006 | 09:16 PM
jonnyn's Avatar
I know what you mean. I have the short shifter and I still grind 3rd on occasion. I've got 3 qts of GMSFM waiting to go in. I hope it helps.
Old Sep 24, 2006 | 09:04 PM
Warren803's Avatar
Short throw does not fix the 3rd gear grind. GMSFM does. I used to have the grind. As soon as i put the GM stuff in, the grind went away and never came back(as long as you dont have the short shift kit). Just installed the short throw this weekend (ITL helped me install it) and the 3rd gear has started fighting with me again. ITL installed the corsasport bushing on his car this weekend also. He already had the short shift kit installed. He said the bushings makes if feel much much better and fixed the smoothness of shifts and the fighting of the 3rd gear. My next purchase will be the bushings.
Old Sep 25, 2006 | 07:25 AM
clsdave's Avatar
2005TL(6MT)
The hard shift into third is not a good thing and is probably going to cause additional problems later in the transmissions life. As the weather cools it will likely occur more frequently. When you get a chance, change the fluid and make the problem shift go away. You'll be much happier and wish you did it sooner.
Old Sep 25, 2006 | 07:42 AM
ahhh thanks for the tip bro. i'll do that later today after work
Old Sep 25, 2006 | 08:09 AM
clsdave's Avatar
2005TL(6MT)
Have you decided what brand/type of fluid you are going to use? GMSFM? Also let us know your results after the change.
Old Sep 25, 2006 | 08:38 AM
GMSFM since everyone seems to be having success with it. How much is it?
Old Sep 25, 2006 | 09:09 AM
clsdave's Avatar
2005TL(6MT)
It wasn't cheap. It think about $11 or $12 a quart (you need 3) but don't remember exactly, it was a while ago. But well worth it since the problem is gone. GM makes more than a couple of types and one that seems to look/sound similar to the GMSFM. Make sure you get the correct one.
Picture and part number here:
https://acurazine.com/forums/showthr...ighlight=GMSFM
Old Sep 25, 2006 | 09:49 AM
becker800's Avatar
I talked to my dealership for the 2nd time about this.
I had them install the new Acura Transmission fluid. This DOES seem to help the 3rd gear problems. Shifting does seem smoother, it didnt TOTALLY get rid of it but its only happened once since I got it put in. I also have the short shifter installed.
Generally with any SS, it makes shifting a bit rougher.
My dealership installed it for free so maybe your local one will do the same. I think my dealership was interested in the results so thats why they did it.
Old Sep 30, 2006 | 02:57 PM
FlyingPig's Avatar
Where would you get the fluid changed? At the dealership?
Last time I had a constant gear problem, a honda's tsb fixed it.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
