3rd brake light
Old Oct 20, 2004 | 02:52 PM
Mindcrime's Avatar
3rd brake light
Has anyone had the 3rd brake light issue where it kind of is drooping on one side so the break light shines on your back window at night?
I have my car in the shop today for this and the tech is saying everything is normal and other TL do it. Ummmm, I don't think it's normal to have red light shine all over my rear windows so that I can't see out of it.
If you have had the problem and have had it fixed can you let me know what they did so I can tell this dork where to go.
Old Oct 20, 2004 | 03:05 PM
DaveK's Avatar
Here is a possible fix. I haven't tried it yet myself.
https://acurazine.com/forums/showpos...05&postcount=6
Old Oct 20, 2004 | 03:08 PM
J RIDE 81's Avatar
Team Nighthawk Director
Never heard of this, sounds like something that can be fixed without the dealer. I have a different method that I just thought of. If you'd like PM.
Old Oct 20, 2004 | 03:13 PM
Mindcrime's Avatar
Thanks, the dealer said the clips were set right but maybe they need to check again.
Old Oct 20, 2004 | 08:28 PM
jcentrone's Avatar
mine did it and still has, need to fix this weekend........it stunks at night.
Old Oct 20, 2004 | 09:06 PM
SLVR04TL6PD's Avatar
there are 4 securing points to the cover. 2 are push in and the other two slide to get out. Be careful and you can remove and then re-set them. I removed mine to clean (dusty inside) and found it to be very tight, but not impossible . Don't force anything too hard and it should seat perfectly when you replace it. The rubber outside seal touches the glass on all sides.
good luck
-Chad
Old Oct 20, 2004 | 11:16 PM
Mindcrime's Avatar
good luck
-Chad
I called the dealer back and asked them to check it again as having the break light shine on the back window is not normal and needs to be fixed. He said he would have the tech look at it again. I go to pick up my car, after the serv. dept. closed, and guess what?....it still is not right and all the receipt said was that it is within spec. WTF.
Old Oct 20, 2004 | 11:28 PM
PuffyY's Avatar
I can see some light when the 3rd light is lit, but it's definately not normal to be drooping to one side. Because the light is fairly bright, you should be able to see some red light spill from around it when it's lit, but not shine on the glass so much that you can't see, even w/ the auto-dimming rear view mirror.
Old Oct 21, 2004 | 01:39 AM
rets's Avatar
Moderator Alumnus
This is very easy DIY fix...
This has been a common problem for some TLers...
Besides the link above, it's better to check that pic, too.
https://acurazine.com/forums/showthread.php?t=80600 #7
More info...
https://acurazine.com/forums/showthread.php?t=88941
All list in GARAGE
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
brandnewcolony
Sep 12, 2015 10:39 AM
cruisingnycfl
Sep 2, 2015 12:11 PM
Nicho863
Sep 2, 2015 08:12 AM
