3M Acoustic Thinsulate Sound Insulation (ebay)
Old Feb 13, 2013 | 09:04 PM
Roger555's Avatar
OCD
Those of you who aren't familiar with Acoustic Thinsulate this is one of the best & lightest sound absorbing materials available but hard to get on the consumer market.
I'm sure many of you might recognize now that this is the same stuff Acura used in our TL's from the factory! Although sadly I see many people unknowing rip it out and replace with some inferior closed cell foam which has almost no sound "absorbing" ability.
The truth is Acura did chose a very good sound absorbing material, however they did go with the thinnest version. The version on ebay right now is the thickest 2" version!!
Anyways this stuff is usually very expensive and only sold in full roll quantities (around $1700/roll) and never directly to consumers. I recently found a company selling off some surplus on ebay and purchased 125 sq ft for myself. Great deal and I just wanted to give you guys a heads up they still have a few lots of 125sq ft left.
P.S. I offered 120.00 and it was accepted right away so you might be able to get a better deal then I did.
This is mine after delivery!
http://www.ebay.com/itm/125-sq-ft-3M...49c903&vxp=mtr
http://multimedia.3m.com/mws/mediawe...sulate2008.pdf
Old Feb 13, 2013 | 09:34 PM
Steven Bell's Avatar
Roger, where do you plan on using it?
Old Feb 13, 2013 | 09:58 PM
Roger555's Avatar
OCD
I'm working on replacing all the original with the thicker stuff, or in some cases adding depending on how much space there is.
It might also make its way into a few house projects or power tools. I read a study where they were able to reduce the sound of a router by 8 decibels just by lining the case with this material. Definitely going to try this on my leaf blower too.
I'm a bit obsessed with eliminating squeaks/ Rattles and road noise. I have many rolls of different foams , felts and other such material for eliminating any possible interior noise.
Also for the places you cannot put adhesive backed foam/felts I do highly recommend this anti friction coating product called "Peox DF" which has been working very well for me.
I choose this one over the others because it sticks well to PP plastic which makes up a majority of our interior panels. Also works very well in eliminating the crunch or "stick-slip" sound you hear when the seat belt buckle rubs against the side of the front seats , or the headrest rubbing where it touches the seat.
read up on it here http://squeaksandrattles.info.
Old Feb 15, 2013 | 04:36 AM
hofiveo's Avatar
Have any of you used this guys way of sound deadner http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
What are your opinions on this way of sound deadening?
That kit from the website is $215.00, you can order individually too. Might be helpful when i replace my dash. Thanks for the info.
Old Feb 15, 2013 | 02:05 PM
Gregerst's Avatar
Thanks for the info. I wish they had smaller quantity though. Seems like I lot. I just removed that stuff from the back of my rear seats so I could get more bass into the cabin from my subs. Removing it made a difference so I know it works. I'd like to put some in the trunk behind the trim pieces though.
Old Feb 16, 2013 | 10:07 PM
dannyz's Avatar
TLicious Type S
Thanks for the tip!
Old Feb 17, 2013 | 05:17 AM
hofiveo's Avatar
Got mine before it ended!
mlody
Dec 4, 2019 02:11 PM
Euro4gen
Dec 12, 2015 03:14 AM
07Acuradude
Sep 29, 2015 03:01 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
spoiler900
Sep 23, 2015 04:41 PM
