The 3G Ramblings & General Discussion Thread (Quattro)
#7881
Received 7,772 Likes
If you mean ignition off, i.e. no electrical supplied to the system... No idea.
If you just mean engine off (not running), then because you're not trying to actually sync the gears together. With the engine running and things spinning, there will be resistance to move into gear if the clutch isn't fully disengaging.
From what you've said, the pump-pump-pump to regain function sounds entirely hydraulic. Specifically a failed seal at some point where the liquid is slipping past when you try to build slow constant pressure. But you probably knew that.
I don't remember how to troubleshoot which end of the system the problem is at though.
#7882
No Kevin...not really. That would be foolhardy.
Chad, I'm not sure...my first one failed at 34K...no warning, and before the slave mod. 2nd one, I've had in there since then...so 80K miles with the slave mod and it's going strong. maybe a bad batch of o-rings?
Justin, be my chubby bunny!
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
justnspace (04-22-2016)
#7887
#7888
Shit. This probably means I've been hanging around you degenerates too long. Starting to think the same. Hell, me and BuffetBoy can practically post interchangeably.
I bet all our periods are in sync now too.
(that smiley is acutely disgusting when following that monthly sync comment, I see now)
#7889
#7891
Hey.... Sharing is caring!!!
morning guys need more coffee I think today...
![Yawn](https://acurazine.com/forums/images/smilies/yawn.gif)
#7893
#7894
Need some assistance from some Audio guys. I actually think J is the only one running audio.
So I've heard rear speakers are just for a fill so either A) You don't need to change them or B) You don't need to spend a bunch of money on them. So there probably is no point of running a amp to the rear speakers right?
I really don't want to run 2 amps. IE: 4 channel and/or 2 channel. My idea was to just run a 4 channel to power the 2 speakers up front and the sub.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#7896
#7908
Time to go
-ing...
![BEETROOT](https://acurazine.com/forums/images/smilies/lift.gif)
#7911
I installed a new gramophone in my TL. Right below the cassette deck. Thing bumps.
#7912
Kinda chapped the TL never came with an 8 track option. Dafuq.
#7913
![Bullshit](https://acurazine.com/forums/images/smilies/bs.gif)
Where do you put your records ?
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
#7915
I had Clearwater Audio speakers in the miata. They were fucking amazing sounding. No idea on price or how they compare to others. But they were awesome. People always asked if I had an oem sub in the car. Nope, just quality door speakers!
#7917
3G's have 6CD in deck
#7920
Originally Posted by Oh Sickest TL
what is that??
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
