The 3G Ramblings & General Discussion Thread (Part 2)
Old Aug 3, 2014 | 06:44 AM
  #29481
rockstar143's Avatar
That's literally what I said to get to line up
Old Aug 3, 2014 | 08:14 AM
  #29482
Originally Posted by Majofo
What tf are you talking about nukka.. nothing's lined up in that pic.
Considering you have a frankenstein pair of heads.. those marks don't mean shit unless they properly installed the cams. I'm guessing the cams were pulled with the pulley attached and directly swapped. I'd be concerned that that the front cam was installed in the rear head (I'm not sure that's even possible).
Line this up (highlighted in yellow).. then check to see if the valves are closed on the first cylinder (lobes up). Just for shits, check TDC on the crank, you should see the first cylinder at the peak of the compression cycle (all the way at the top). This means at peak compression, all valves are closed and in time.. keep rotating, exhaust valves open up on the exhaust cycle, piston goes down, intake valves open up as exhaust valves close, then back to compression stroke.
Worse case, line it up by hand by following the valve cycle, as the intake valves close, check the marks.
thanks. I have the crank at TDC. Cylinder #1 is at the top
what I'm trying to say is; when I swapped over the rockers, the rockers are sitting on a high lobe(?) and when I spin the pulley to match up the "yellow marks" on the head, the lobe falls and the mark on the pulley completely goes PAST the yellow mark on the head.
Does this mean I installed the rockers wrong?
Old Aug 3, 2014 | 08:25 AM
  #29483
btw, thanks for explaining it.
for the rear head, TDC should be all closed valves. (just thinking out loud here)
the front head gave me no problems and the marks are lined up. it's at TDC. crank is at TDC.
the rear is blah.
Old Aug 3, 2014 | 08:33 AM
  #29484
Could it be the wrong cam, like he stated? Doubt it
I do recall when lining up the new belt, the front held fine at TDC on it's own but the rear rotated back one like and my mark was where yours is in the picture.
Basically rear 1,2,3 fought me to line up the TDC, I had to get a ratchet/socket on the cam gear to pull it back to line the TDC marks line up as I used the belt to hold it in place (during the counter clockwise from crank pulley taught install of the belt to ensure slack ended up at tensioner).
Does that make sense?
That's why I was thinking that maybe without it being on the car with belt in place, it just wouldn't hold on it's own...maybe a characteristic of the cam lobe on the rear for TDC?
Old Aug 3, 2014 | 08:37 AM
  #29485
^okay, im thinking the same.
without the belt, its hard to hold TDC on its own.
Old Aug 3, 2014 | 08:58 AM
  #29486
Well, I could be totally wrong, man...but I TOTALLY do recall the rear cam rotating back a mark and I couldn't get it to stay until I used the ratchet and then routed the belt tooth over it to hold.
Old Aug 3, 2014 | 09:07 AM
  #29487
I havent even finished putting all the timing belt stuff in.
so, I cant even use the belt at the moment.
the service manual says to get rear head at TDC before putting it on the short block.
I was thinking of installing the heads, then finishing the timing belt pulleys, then I can loop the belt over the head pulleys. butt, if rear head isnt at TDC, I dont want to install yet!!!
Old Aug 3, 2014 | 09:10 AM
  #29488
Old Aug 3, 2014 | 09:15 AM
  #29489
I don't know, man...I'm sorry. This is new territory to me.
Old Aug 3, 2014 | 09:17 AM
  #29490
Yumcha's Avatar
I don't suppose Justin has an experienced car mechanic in his friends and family list to call?
Old Aug 3, 2014 | 09:20 AM
  #29491
<---same. I dont know what the fuck im doing..
Majofo, rescue me!
Old Aug 3, 2014 | 09:21 AM
  #29492
Nawwww...let us help him fuck this shit up. That's my vote, at least.
Old Aug 3, 2014 | 09:25 AM
  #29493
^at least I will learn
and I can halp you fuck up your projects!
Old Aug 3, 2014 | 09:53 AM
  #29494
swoosh's Avatar
takin care of Business in
Justin, is there a reason you dont have any cylinder marks on your cam pulley?
The cam pulley should have cylinder marks on them
EDIT: nevermind that, the rear does not have cylinder marks on them, just the TDC
Old Aug 3, 2014 | 10:00 AM
  #29495
yup, the rear just has TDC mark
Old Aug 3, 2014 | 10:01 AM
  #29496
im about to disassemble the rear head and start all over again.
maybe, in haste, I didnt line up the pulley to start with.
Old Aug 3, 2014 | 10:04 AM
  #29497
swoosh's Avatar
I was about to say that but didnt want to due to the limited knowledge I have on this subject....
the only thing which I was reading said "do not force the cam pulley to turn when it offers resistance"....now this could be applicable if the heads are installed on the car (with the belt off) and not when the heads are off the car....it did say that you can damage the valves by doing so....
Old Aug 3, 2014 | 10:05 AM
  #29498
^fuck.
lol
my valve springs arent tight tho. they are super loosened.
butt, I'll start over anyway.
Old Aug 3, 2014 | 11:48 AM
  #29499
so, I started over.
Old Aug 3, 2014 | 12:14 PM
  #29500
outcome?
Old Aug 3, 2014 | 12:29 PM
  #29501
Yumcha's Avatar
Well, so long as what Crabs is attempting to do is...reversible?
Old Aug 3, 2014 | 12:31 PM
  #29502
Majofo's Avatar
You guys can sure fill up a page with bullshit.
Justn, at TDC, are the valves closed on the cylinder 1?
It's super difficult to fuck up a rocker installation. It's almost fool proof.. but just for shits, show us your handy work.
If done correctly (I doubt you could swap rocker arms, rollers should be down on cam lobe, valve rockers angled in), it shouldn't effect the timing at all.
Old Aug 3, 2014 | 12:36 PM
  #29503
Yumcha's Avatar
I take to robotsh*t, thank you.
  #29504
affect
Old Aug 3, 2014 | 12:41 PM
  #29505
I started over.
this time, I made sure I aligned TDC before I tightened the pulley.
last time, I didnt take note of where the pulley is supposed to go and just tightened in haste
I have my old J32 head to compare.
  #29506
Majofo's Avatar
affect
stick to bs numbnuts
Old Aug 3, 2014 | 12:42 PM
  #29507
Majofo's Avatar
I started over.
andd.... are the first cyl valves closed?
Old Aug 3, 2014 | 12:47 PM
  #29508
like so?
1st cylinder is where my left arm is holding up the piece of engine
Old Aug 3, 2014 | 12:54 PM
  #29509
now, Im questioning my front head rail swap.
in theory; #5 should be closed and the others slightly open.
but when I look at my front heads; all of them are shut
Old Aug 3, 2014 | 01:28 PM
  #29510
^majofo, assistance please!
Old Aug 3, 2014 | 01:32 PM
  #29511
swoosh's Avatar
Text Maj....also text Robert...maybe he will be able to help you as well
Old Aug 3, 2014 | 01:34 PM
  #29512
Majofo's Avatar
It looks like the intake side is slightly open, is it closed?
Old Aug 3, 2014 | 01:41 PM
  #29513
yes kind of protruding.
but I dont "see" any air entrances.
Old Aug 3, 2014 | 01:43 PM
  #29514
do I have to back in and align it!?
Old Aug 3, 2014 | 01:47 PM
  #29515
Majofo's Avatar
What's going on with the 3rd cyl valves?
Old Aug 3, 2014 | 01:50 PM
  #29516
exhaust are open
Old Aug 3, 2014 | 01:51 PM
  #29517
please excuse my laboratory...backyard mechanic is at work here.
Old Aug 3, 2014 | 02:29 PM
  #29518
swoosh's Avatar
Justin, am just thinking out loud here and I bet Maj will come in and yell at me...
while 1 cylinder is in compression (both valves closed), the other is in intake (intake valves open) and the 3rd is in exhaust (exhaust valves open), that does look ok to me...again this is just from theory and my my head talking out loud....
Old Aug 3, 2014 | 02:31 PM
  #29519
swoosh's Avatar
just looked up the firing order and does seem in sync with my thinking
https://acurazine.com/forums/2g-cl-2001-2003-50/firing-order-739865/
Old Aug 3, 2014 | 04:25 PM
  #29520
