2008 TL A13 Service
2008 TL A13 Service
My TL has around 75k miles on it and the service light just came on for the A13 service. From what I understand, this is an oil change, tire rotation, and ATF replacement.
I bought the car certified last year with around 64k and based on the work order I got with it, it looks like they changed the ATF right before I bought it. The work order says 'TRANS SERVIC PERFORM MINOR TRANS SERVICE' and credits 4 units of ATF.
Does this sound like the same thing? If so, does it need to be done again so soon? Am I going to run into warranty troubles if I decline?
Thanks.
Thanks.
Where Did My Garage Go?!!
You will not run into warranty problems although it wouldn't hurt to flush out the crap fluid that is in there.
I would certainly change out 3rd/4th gear pressure switches as preventative maintenance though https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Welcome to the forums!
08_UA7_Gr33k
02-11-2016 02:17 PM
