2008 Acura TL Base Pressure Switch Help
My shifts are becoming more sloppy and rough so I'm thinking to do a pressure switch swap. After looking around I found lots of information for the 2004-2006 but I'm wondering if the parts needed are the same. What part numbers do I need amd where do you recommend I get them from?
No the part is not the same for 04-06 to 07-08, in both case parts are # are not even the same since they are using update part number. Parts can be obtain from any AZ Acura vendor here or at your local Acura dealer. There are already tons of threads about parts number along with numerous DIY. I hate spoon feed.....
