2007 TL-s Center High Mounted Stop Light
5th Gear
I just bought my 2007 CBP TL-S auto w/nav in June. The production date is 05/07. I found that the Center High Mounted Stop light on my TL flashes (bright & dim) 4 times each time you apply the brakes. It stays on bright after the 4th flash. Is this new on the 2007's, I called a dealer here in Calif and they were unaware of the feature and wanted me to bring the vehicle in. If anyone else has this feature on there type-s let me know. Maybe I got one thats truly different. I just haven't seen any others that flash.
1st Post, Thanks
1st Post, Thanks
5th Gear
Hi all, maybe this was not the best 1st post. I just saw a NBP TL-S today in Riverside, CA. Curious to my first post, I followed it and saw that the third brake light did not flash as mine did. I've seen that several have viewed, but no post. Please let me know if the flashing third brake light is normal. This is my first acura and I'm really impressed with the TL-S, this car really rocks.....
5th Gear
thanks for the reply, I'm thinking about taking it to the dealer because it maybe defective, not sure. I just dont want to look stupid, if its normal. I've check all around the forum and have'nt found anyone else with the same question or concern.
Dealer installed a third brake light module. They were popular around 2000 - 2002 but were causing accidents because people did not know if you were really braking. Have them remove it when you go in for service.
There's alot of asian in
dont remove it
Originally Posted by sifuacura
are u sure u talking about the 3rd gen tl here buddy? those dont light up unless we hit the brakes.
dont remove it
dont remove it
well, if he says everytime its after the 4th flash it stays bright, that might be a aftermarket flasher module installed, some people pay to have that done. if it was put there on purpose, don't remove it, its actually pretty useful. flashing leds gets more attention from behind then just on and off.
Oakes
Wash & Wax
10-12-2015 11:17 AM
