2007 TL 5AT Transmission Ratios and Performance
Ok guys, ive been doing my homework and wanted to know if the difference in the 06 to the 07 auto tranny, does it make the 07 TL perform better?
Here are the ratio's for the 06 and 07:
2006: 2007:
1st 2.563 1st 2.697
2nd 1.552 2nd 1.606
3rd 1.021 3rd 1.071
4th 0.666 4th 0.693
5th 0.480 5th 0.490
Reverse 1.846 Reverse 1.888
Final 4.428 Final 4.312
2006: 2007:
1st 2.563 1st 2.697
2nd 1.552 2nd 1.606
3rd 1.021 3rd 1.071
4th 0.666 4th 0.693
5th 0.480 5th 0.490
Originally Posted by PeterUbers
Shorter gearing = better performance in '07. Other factors that can change from year to year in a tranny is
1) shift timing
2) rpm at which torque convertor locks up
-- have these two variables changed? All else being equal, shorter ratios in 07 = better performance.
1) shift timing
2. I think they changed that as well.
HERE is the link that shows all the changes they did to the '07.
"The torque converter is now calibrated to offer more progressive acceleration than in the past, coupled with better acceleration at large throttle openings. "
Yeahp... the new tranny offers better performance (straightline acceleration and rolling acceleration) ..
<i'm jealous!>
<i'm jealous!>
The 07 TL has higher performance but at the expense of higher RPMs in each gear. I'd rather be able to do highway speeds (80+) with a lower 5th gear RPM than to have the slightly added performance.
..... and that is why I own the 6spd MT TL... NBP. Ya want to get serious with the performance go 6MT. It's fast as hell..... 5.7 sec.
I heard that the '06 and below TL's die out in fourth gear thats why i was intrested in knowing more about the transmission changes made on the '07. im a new member that is currently driving an auto rsx that dies out in thrid gear. i like the build quality of acura's and the service they provide at the dealer for repairs, so am looking to upgrade to the TL, but want a car that can hold its own on the highway. whats the 60-100mph time for the TL?
Yeah... the TL dies in 4th gear... but it's a blessing and a curse... the taller 4th gear helps with fuel economy in highway driving .. but takes away, of course, from more spirited and well-spaced downshifting when accelerating at highway speeds.
I don't really notice it -- I have the AEM CAI on my 5AT and my engine has been WELL broken in at 70,000 miles .. and it can cook on the highway -- i'm not disappointed (all things considered).
Would love to see a Mercedes/Lexus-esque 7 or 8 speed auto tranny in the Acura lineup one day soon -- that would blend VERY well with VTEC (IMHO). I was recently in an ML350 and that 7-speed auto made that heavy SUV cook at all speeds .. i was very impressed.
Any '07 5AT drivers out there that care to give a review on the performance aspect of your TL?
'10 Hyundai Genesis Coupe
Yeah the 04-06 TL dies at fourth gear. It's quite a difference when you shift out of third, although 2nd and 3rd gear are great and that'll take you from 40 (right out of first gear) -105mph (top of third gear).
I want to see if I can pop the Integra Type-R gears into this tranny and hope for the best. Worst case I'll just replace my old tranny with an 07, it'll help a bit.
Although one thing to point out is the long second and third gears help you stay in your powerband longer, when you're in the gear but once you shift it hurts being out of V-tec for that brief moment.
I'm somewhat exagerating this, it's not that bad, but fourth gear does suck ass, but I'm fairly sure that with shorter gears the TL would be considerably faster.
According to your numbers and a tire size of 235/45/17
06 speed at 7000rpm in each gear
- 1st: 46.47mph
- 2nd: 76.75mph
- 3rd: 116.66mph
- 4th: 177.85mph
- 5th: 248.15mph
- Reverse: Who cares
07 speed at 7000rpm in each gear
- 1st: 45.35mph
- 2nd: 76.16mph
- 3rd: 114.21mph
- 4th: 176.50mph
- 5th: 249.63mph
Performance gains (or losses) are as follows:
- 1st: 2.5% gain
- 2nd: .8% gain
- 3rd: 2.2% gain
- 4th: .8% gain
- 5th: .6% loss
I just wonder why they bothered changing EVERY SINGLE GEAR (including the final drive) for such minimal differences. Makes me glad I bought a manual...
- 1st: 46.47mph
- 2nd: 76.75mph
- 3rd: 116.66mph
- 4th: 177.85mph
- 5th: 248.15mph
- 1st: 45.35mph
- 2nd: 76.16mph
- 3rd: 114.21mph
- 4th: 176.50mph
- 5th: 249.63mph
- 1st: 2.5% gain
- 2nd: .8% gain
- 3rd: 2.2% gain
- 4th: .8% gain
- 5th: .6% loss
For comparison, here are the speeds of the 6MT at 7000rpm (2005 6MT gear ratios used)...
1st: 41mph 13.3% gain
2nd: 65mph 17.2% gain
3rd: 94mph 24.1% gain
4th: 128mph 39.0% gain
5th: 165mph 50.4% gain
6th: 208mph
6th: 208mph
Yeah ... my TL "cooks" on the highway in that it's very spirited and "quick" on the highway -- 3rd gear passing power is solid for a V6 sedan -- better than the G35 ('06) and my '03 Nissan Maxima 4AT.
The TL "does" come with a factory cold air intake (LOL!) .. it's more like a very conventional factory air induction system with the inlet baffle pointed OUTSIDE of the engine bay to suck in cooler air... i like to call it a "cooler air intake system." It is still VERY tortuous (windy) and air restrictive and not a very free-flowing system. When you install it yourself (as I did) you'll see all the rinky dink plastic parts that are part of the intake and resonator (stock) that come out ... and then you replace it with this simple, free flowing AEM intake TUBE! I'm not surprised there are such phenomenal gains from just a CAI (15-18 whp)
What the TL/RL/TSX eventually need is a 7 or 8 speed automatic tranny.
Also was the CAI install difficult? Any cutting or drilling required? Is the CAI piping very long? how bad was throttle response affected? Sorry for all the qustions but i gotta get all the info i can get. thanks
Originally Posted by speeddemon69
so the TL is quicker than the G35 that uses the same engine as the 350z? i was looking at the G35 as an option also (coupe). i was looking at the gear ratios on the 5AT version of the G35 and it looks like its a fourth gear is better than the TL's. But then again the G35 does have more powerterrain loss.
You have to look at a much more specific window than simple gearing. You must compare the gear ratio, the final drive, the tire size, drivetrain loss and the torque @ xx rpm of both cars to acutally compare the performance on paper. If the torque is high, but the gearing is too long, you won't perform. If the torque is high, the but the tire is big, you won't perform. If the torque is high, but the drivetrain is dragging, then you won't perform.
One thing that I don't see mentioned is that the '07 Type S has it's VTEC engagement set at 5000 RPM as opposed to the 3.2L engine set at 4700 RPM. So, the non-vtec period between upshifts seems it might be (speculation) even more painful with the 3.5 engine.
Originally Posted by Inaccurate
This is "the" place. Why do you ask ???
Just making sure there is not another TL site that's more active.
I was just joking around with you...
BTW, welcome to the forum, the best Acura forum on the Net !!
You saying we are not "active" here ??? :angryfire
Team Anthracite
the difference is really minimal when you think about it.... Multiply gear ratio and final drive together!
07 is only slightly faster in acceleration. (really slightly.) but dunno about the actual tq converter =)
If the 5000rpm changeover of the Type-S creates that "kick in the pants" feeling, you are basically getting hosed...
The TL in 3rd gear passing is QUICKER (IMHO) than an '06 G35 5AT -- I am NOT talking about 4th gear passing ... The G35 is also a MONSTER out of the hole (i.e. 0-60 compared with the TL .. thanks to that Nissan torque). I always hated how the TL took 'till 3800 rpms to really feel like it was built up to some decent power. Now, however, with my CAI and OVER 70K miles on the car, I feel like that my throttle tip in is improved (i.e. throttle response is improved) and I have some more juice low in the rpms.
The CAI install was not difficult, but cumbersome at times. I say that because all of the connections/installation necessary above the wheel is straightforward (i.e. removal of old factory intake parts and connections of new CAI parts...). It gets challenging when you have to remove the wheel, remove the fender lining, and drill a couple rivets in the factory resonator to remove the stock components completely. Other than that, it's a 2/10 in terms of difficulty. It took me 1.5 hours start to finish.
I have driven my TL extensively, obviously, and a friend's '06 G35 5AT fairly extensively (and aggressively) .. and it's a big trade off for me .. I love the infiniti low-end torque, and the exhaust note on the infiniti is intoxicating! However, I like the creature comforts of my TL more (bluetooth useability and features compared with the Infiniti BT, ELS sounds, satellite radio, ergonomics of TL's interior) and I liked having that high end power on the highway.
The nice thing about low-end torque (ala the Infiniti) .. it always feels like it's "pulling" hard ... even though you could be neck and neck with a TL that doesn't give you that feeling of aggressive acceleration b/c of the way it delivers the power in the rpm band. Does that make any sense?
mrkingstonvi
02-22-2016 01:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
09-17-2015 09:01 PM
09-15-2015 06:44 PM
