2006 cabin air filter change problem
has anyone changed their 2006 cabin air filter? i just bought a new purolator c35519 and went to access the filter and it looks like the glove compartment has been reconfigured. i can't figure out how to dismantle the glove door.
i just finished replacing the filter. all went well once i figured out how to drop the door to the glove compartment. only busted 3 of the 10 mounting clips on the left side. next time i will do the cut out with my dremel.
... or is the 2006 procedure different from that described in the Garage?
i have an 05.. pretty much drop the glove box door, unlatch it from its arm.. a couple of screws than appear, a bunch of clips and viola....... 2 clips on the air filter door and pull out
these are links that i used. it just took me a while to figure out how to drop the glove compartment door.
https://acurazine.com/forums/showthread.php?t=87494
https://acurazine.com/forums/ramblings-12/firewall-help-123884/
https://acurazine.com/forums/showthread.php?t=108345
https://acurazine.com/forums/ramblings-12/best-place-buy-snowboarding-pants-jackets-122290/
https://acurazine.com/forums/showthread.php?t=131831 Replacing the filter without removing the entire glove box
sputik
Sep 7, 2015 01:40 PM
