2004 TL tranny fluid change?
All, somehow I have managed to go about 100k miles since the last time I had the tranny fluid changed. The fluid level is fine, but it is all black. Should I risk have the tranny flushed and filled? I have read that this might lead to unmasking a real problem. The tranny still shifts fine and is not slipping. The car currenly has 152k miles on it, and I do intend to keep it for the next few years. What say ye?
Mauser, you've been on here for over three years. You must have searched and found that nearly no one does a full hardcore flush. Standard drill (especially for black ATF fluid) is do a 3x3 drain/fill and give the new fluid some miles to mix in with the old each time. Do the recommended pressure switches somewhere in there and call it good.
Yeah, saw that. Also saw that he's level 29 with almost 2400 points. Guessing that means mauser's been on the site quite a bit. But I know where he's coming from. Always like to ask the question before possibly destroying a tranny...
No idea what the points or levels mean, but thanks for the suggestions anyway. I have not posted much here as my TL has been a great car, and has not needed anything outside of normal maintenance.
So, I should do the 3x3 fluid drain and fill over the span of what time frame? A week, a month?
Look at the ATF change threads in the Service Area. Here's one example:
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/
Generally, it looks like people are doing the 3x3 over the course of three weekends.
if your old fluid is that bad, you might even want to consider doing a 4th or 5th drain and refill, try to get as much of that old fluid out as possible.
I do a single drain and refill every 10k along with my oil change.
NOW, if you've rounded off the bolt then you're in dark waters at this point.
are you using a 6pt socket? try and budge a smaller than 17mm on there and crack it loose...then replace the fill bolt with a new one.
mada51589
Jan 9, 2025 04:40 PM
HeloDown
Sep 8, 2015 06:51 PM
