2004 ACURA TL - Steering wheel vibrations
Old 03-13-2022, 09:46 PM
COLDSTEELSOLDIER1's Avatar
Great evening guys... So I recently purchased a 2004 Acura TL -96000K Miles on there. I have a problem with the steering wheel shaving and vibration violently and noisy at speeds of up to 50 mph. I took it to a shop in my county and was told I needed to get the wheel alignment. I did the alignment but it was still shaking. I took it to another mechanic he took it for a test drive and I was told that I needed to changer the front control 🛂 arms. I got it changed. Still shaking. I need some advice as to what may be the problem. I am tired of spending 💰 money on this car with the problem being unable to be resolved... What should I do. Thanks... thanks 🙏🏿🙏🏿🙏🏿
Old 03-13-2022, 11:36 PM
Synchro's Avatar
@COLDSTEELSOLDIER1 Have you had your tires/wheels checked for balance and abnormal wear?
Bad suspension and alignment will damage your tires.
Old 03-14-2022, 12:09 AM
Jackass's Avatar
Shaking wheel is usually one of the following:
- brake issues - usually more prevalent when applying brakes vs just straight line driving
- bad axles or CV joints - usually more prevalent under acceleration or turning
- bent rims
- damaged tires
- out of balance wheels
Old 03-20-2022, 09:17 AM
DMZ
Head a da Family
DMZ's Avatar
- bent rims
- damaged tires
- Warped rotors from improperly torqued wheel lugs. That's the when applying brakes part. They should always be tightened to 80 ft-lbs.
frank358fr
02-28-2010 08:10 PM
Yawannabelikame
01-28-2009 09:47 PM
dansmith2004
11-01-2008 12:50 PM
LJ2000
10-16-2005 11:57 AM
bmterp
09-17-2003 12:01 PM
Quick Reply: 2004 ACURA TL - Steering wheel vibrations
