2004 ACURA TL - Steering wheel vibrations
Great evening guys... So I recently purchased a 2004 Acura TL -96000K Miles on there. I have a problem with the steering wheel shaving and vibration violently and noisy at speeds of up to 50 mph. I took it to a shop in my county and was told I needed to get the wheel alignment. I did the alignment but it was still shaking. I took it to another mechanic he took it for a test drive and I was told that I needed to changer the front control 🛂 arms. I got it changed. Still shaking. I need some advice as to what may be the problem. I am tired of spending 💰 money on this car with the problem being unable to be resolved... What should I do. Thanks... thanks 🙏🏿🙏🏿🙏🏿
@COLDSTEELSOLDIER1 Have you had your tires/wheels checked for balance and abnormal wear?
Bad suspension and alignment will damage your tires. |
Shaking wheel is usually one of the following:
- brake issues - usually more prevalent when applying brakes vs just straight line driving - bad axles or CV joints - usually more prevalent under acceleration or turning - bent rims - damaged tires - out of balance wheels |
Originally Posted by Jackass
(Post 16803711)
- brake issues - usually more prevalent when applying brakes vs just straight line driving - bad axles or CV joints - usually more prevalent under acceleration or turning - bent rims - damaged tires - out of balance wheels . |
