2 questions.
2 questions.
fisrt: my trunk release button stopped working. ive already taken off the lower part of the dash to mke sure its plugged in. IT IS. why do you think it stopped working?
second: wahts the cost of having ACURA VS DO IT YOURSELF oil chage (service B) cost wise? my sister use to work at acura so i never had to worry about it.
also if i do it myself how do i reset the computer?
gracias!
gracias!
B1 Service is Oil Change plus Trire Rotation plus "24 point inspection"? If so, ~$60 max with stock filter and "Synthetic blend" oil. DIY = ~$30 with a better filter and full synthetic oil.
There is an excellent step-by-step Oil Change check list with Service Manual Scans around here somewhere. Try the 3G Garage:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Computer Reset = disconnect NEG battery terminal. If you disconnect during service/mods you don't have to worry about it later (and no CEL's if certain sensors were unplugged during the mod). Reconnect when service/mods are complete.
IF you disconnect your NEG terminal make SURE your have Radio and Navi codes.
1)
2) Oil change at my dealer was just over $50. DIY is about $27.
3) That's three questions, not two. If by computer you mean the ECU, do what Bearcat said. If by computer you mean the MID, https://acurazine.com/forums/3g-tl-2004-2008-93/oil-life-reset-3g-garage-f-157-a-556666/
On the trunk release button, look in your glove box and make sure the little lever in there didn't get pushed to the lock position. That lever disables the trunk release buttone for security reasons.
I do my own oil changes and tire rotations. Cheaper and I enjoy it.
^^^ all three of you are awsome/genious... learned from all three
bearcat94: cheaper to do it myself, and will be using better oil (ill take this route)
chill_dog: i asked three questions not two. lol (i have to learn how to count)
LoveMyTL-S: Lock switch in the glove compartment. (works now)
emailnatec
29
Sep 28, 2018 04:27 PM
BoricuaTL
Apr 8, 2016 01:08 PM
