A-134 Service
Old Oct 18, 2010 | 03:23 PM
reisb's Avatar
A-134 Service
I've got 2007 TL with just over 105k miles.
My A-134 Service light just came on.
Do you have to change Timing Belt, spark plugs, etc? I called Acura and they said service was $1520.
I usually get my oil changes, tires rotated, filters changed etc at Honda since they are reasonably cheaper.
Honda says $900 for timing belt and $245 for spark plugs. Oil change is about $40 and Transmission fluid is about $80.
Should I just call Acura and see how much for timing belt/spark plug? Again, is this necessary based on mileage? I'll do it if so, but don't want to spend that much $$$ if not necessary. I do mostly highway driving if that matters.
Old Oct 18, 2010 | 06:30 PM
BradE's Avatar
Yes, you have to get it done. If the timing belt breaks, the engine is trashed.
Old Oct 18, 2010 | 06:38 PM
rtibbitts07's Avatar
I'd do the 105k service at the Honda dealer, but skip them doing the plugs for $245 and do it yourself....
I got the NGK Laser-Iridium plugs for $60, and had to get a socket extension and a thing like an antenna but with a magnet on the end to pull the plugs from the back side of the engine out, and it took about 2 hours, first time changing plugs on a car.
Old Oct 18, 2010 | 07:11 PM
ggesq's Avatar
Ask them how much labor is to do the TB/WP job. You can buy the TB kit from Kaleb (AZ vendor) for $295.00. Alternatively, contact Honda or an indy mechanic that you trust and find out how much the labor would be. Kaleb sells the plugs as well.
https://acurazine.com/forums/3g-tl-2004-2008-93/complete-timing-belt-kit-special-%24295-763445/
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
