11:1 compression - can someone explain please
Re: 11:1 compression - can someone explain please
Originally posted by meathead
can someone break down what this means?
Moderator Alumnus
Here is the additional info.
From How to Help an Engine Produce More Power by Howstuffworks
Increase the compression ratio - Higher compression ratios produce more power, up to a point. The more you compress the air/fuel mixture, however, the more likely it is to spontaneously burst into flame (before the spark plug ignites it).
Higher-octane gasolines prevent this sort of early combustion. That is why high-performance cars generally need high-octane gasoline -- their engines are using higher compression ratios to get more power.
Re: Re: 11:1 compression - can someone explain please
The compression ratio is the volume above the piston with the piston at the bottom of the stroke, divided by the volume above the piston with the piston is at the top of the stroke.
The intercooler's main purpose is to allow the boosted air to compact a bit as it cools, so even more oxygen gets into the cylinders.
Frankly, I am surprised the TL runs on 93 with 11:1. The new engine computers are doing an amazing job, along with the advanced engine design.
A bit OT but, is it going to be a must that we run 93/premium in our TL's? I used 93 in my Jetta b/c it just seemed to run better. I guess I should expect to go back to 93/premium come mid-Feb.
The manufacturer seems to think so. If you ran 87 the car would not self-destruct, but you would be down on horsepower and the car would knock quite a bit (that "ping" sound) when it was turned off. Over a long period of time it might do some damage, but I don't know for sure.
If you can afford a TL, you can afford 93. If you can't afford 93, you can't afford a TL.
Moderator Alumnus
Originally posted by ramilford
Acura recommends 91 NOT 93.
Sorry, above 91 should be fine. Otherwise, I hardly find somewhere selling 91 here...
Gasoline generally has an octane level of 93, but is blended with an octane level of 91 on the West Coast and in some other geographic locations.
1fatcrxnem1
22
06-01-2018 01:23 AM
phillyguerrilla
09-26-2015 11:27 AM
