105k service and price
So I just came back from my 105k service, spent $1260.53 for the following:
-tranmission flush
-replacement irdium plug
-coolant flush
-powersteering flush
-oil change (synthetic oil) with oil filter
-timing belt
-water pump
-cabin air filter replacement
-service A124
-lube mirrors pivots and clutch
Was this a deal or no deal ?
-tranmission flush
-coolant flush
-timing belt
-water pump
-service A124
3G TL/2G MDX Owner
if this was at a dealer...then it's a good deal since you also had the tranny flush, oil change, coolant flush, PS, and cabin filter replaced, NOT just the TB service (including the tensioners and water pump).
I have my 105k service coming up soon, this seems like an ok deal for evertyhing you're getting, but curious as to what others paid for the same thing. I usually do my own maintenance but won't mess with the timing belt.
Q('.')=O
I have mine coming up and am going to a shop that specializes in Honda/Acura (was recommended by someone in the local forum)
Timing belt & drive belt & tensioners & water pump & coolant + labor = $500. Spark plugs + labor = $125.
If I went to the dealer I would be spending double that.
Mo05TL (05-15-2012)
Received 3,824 Likes
Dude seriously, did you go to a dealer or what?
They probably just drain out your transmission and coolant and replace. I plan on doing all the small things myself and just getting them to replace the timing belt and tensioner.
-tranmission flush
-coolant flush
-timing belt
-water pump
-service A124
-tranmission flush
-coolant flush
-timing belt
-water pump
-service A124
too much.
mrkingstonvi
02-22-2016 01:53 PM
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
