105k good price?
105k good price?
Browsing Acura site and saw this. I'm almost due for it at 95000k. This is at Cerritos, CA. Acura dealership.
http://www.cerritosacura.com/specials/service.htm
TL, CL, MDX
Timing Belt Special
Timing Belt Special
Acura recommends replacement every 105,000 miles or 7 years.
Our Acura trained Technicians will
replace your timing belt, water pump and engine coolant. We will also replace your A/C, Alternator & Power Steering drive belts.
We will inspect the tensioners, cooling system hoses, and cam seals & crank seals for wear.
We will also wash & vacuum your Acura when finished.
A $1,170 - $1,300 value for just
$856
$856
Buy the parts from Gates. Everything is OEM except the water pump, and the kit is only $163 from Rockauto (Gates part number TCKWP329). Kit includes:
- Gates belt (Gates/Unitta make Honda timing belts)
- Gates water pump (aftermarket, but great quality)
- Hydraulic Tensioner (same as Honda)
- Koyo Tensioner bearing (same as Honda)
- Koyo Idler bearing (same as Honda)
After that all you will have to buy is a serpentine belt (Gates K060841 for $20), and two gallons of Honda blue coolant ($30-40). BTW: You can always find 5% off coupons for rockauto on google. I just installed one of these kits for my 04 Pilot and it really IS the best way to go.
You shouldn't have any trouble getting the marks lined up. Before you cover everything up, you turn the motor around twice by hand to be sure everything stays where it should.
I haven't done my Acura yet, but I've done two Honda pilots with similar J-series V6's.
takin care of Business in
but yeah if you havent done the plugs and the flushes, then consider those as well....if you have done it then 94eg has possibly laid it out the best way possible....
OEM NGK Laser Iridium plugs are easy. You can get them through Advanceautoparts.com for $49 shipped with $20-off coupon RETMENOT123. They take about an hour to DIY. You won't find a better price than that on those plugs.
Coolant gets flushed when you change the pump.
Steering flush is an easy DIY for the cost of two bottles of Honda fluid (not required).
And trans flush is easy too. Buy a case of Honda DW1 trans fluid ($12 qts) and change it out once a week, 3 weekends in a row. Probably cost about $100 though.
But yeah, if you get a deal and don't enjoy working on your car, have someone do it.
^^^ dude i dont let anyone else touch my car unless i know its something i can mess up....
am just saying "what else my dealership was quoting me for"....
i did the spark plugs are home, asked the dealer to flush the coolant as it is done with the Water Pump and I flush my tranny/PS/brake bleeding/air filters everything myself in my car port.....
BlkTxAcuraTypeS
10-18-2015 08:05 PM
