100k plus maintenance
Old Aug 3, 2014 | 11:00 AM
desakatao's Avatar
Hello everyone, i recently just bought a 2008 tl type s with 106k miles. i know theres probably a thread out there but what i found didn't really say where i could purchase the parts. ok so i want to know is what kind of maintenance i should do to the car with the mileage and where i could get the parts. like timing belt and all thats necessesary to keep the car running smooth.
your response would be appreciated. am more of diy guy so any inside would help.
Old Aug 3, 2014 | 11:23 AM
EL BAN's Avatar
Road Racer / Solo Addict
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
Parts would be your preference really.. There are some vendors here that put together a kit.. I. Did this job last Friday and also included the engine mounts just to get the car feeling completely new..
Old Aug 3, 2014 | 11:30 AM
desakatao's Avatar
thanks for the quick reply. how much did u spend in parts?
Old Aug 3, 2014 | 11:42 AM
EL BAN's Avatar
For the timing kit it should be around 300..
I spent much more because I included all engine mounts..
Old Aug 3, 2014 | 11:52 AM
desakatao's Avatar
Do you have a link where i could get this kit and also if you can send me the info on the mounts i would prob do it to just to be safe.
Old Aug 3, 2014 | 11:57 AM
EL BAN's Avatar
No link my friend, i just sat down in http://www.acuraautomotiveparts.org, took note of all the parts I needed and sent for quote..
I didnt buy a kit, made a list a while ago and sent to my Acura parts source.. Iwill search my email and if I find it I will post it here..
Search is your best friend, if you try searching here directly in the forum and dont get results try searching in google for the topic and add acurazine at the end and usually that pops up..
Old Aug 3, 2014 | 12:03 PM
pohljm's Avatar
Search amazon for the Aisin TKH-002 kit and then you will need two camshaft seals and a crankshaft seal and a serpentine belt too. This was the best kitI could find with quality parts. It is like $170.
Old Aug 3, 2014 | 12:17 PM
desakatao's Avatar
Alright thanks guys
Old Aug 3, 2014 | 12:43 PM
Mr24v's Avatar
2007 6MT TL Type-S
Here are the parts that I replaced during my 105K:
(TKH-002)
Timing Belt
Timing Belt Tensioner
Timing Belt Adjuster
Timing Belt Idler
Water Pump w/ Gasket
Spark Plugs
Drivebelt
Thermostat
Head Cover Gasket Set
Cam Seals
Crank Seal
Lower Radiator Hose
Upper Radiator Hose
I also had the brake fluid flushed, and the transmission fluid changed since the maintenance history of the car was unknown when I picked it up.
Old Aug 3, 2014 | 03:04 PM
desakatao's Avatar
thanks i lot . def will be getting this parts soon.
Old Aug 5, 2014 | 12:41 AM
Kidquick91's Avatar
5th Gear
When replacing the mounts do you guys prefer oem or aftermarket?
Old Aug 5, 2014 | 02:35 PM
desakatao's Avatar
Am gonna buy aftermarket ones from one of the vendors here.
Old Aug 5, 2014 | 04:52 PM
Sbarbee54's Avatar
Security Dude
This is what i did, now mine was for a type s so some parts could vary
I had them do a whole system coolant flush, timing belt water pump the 3 major pulleys and tensioner, serpentine belt, power steering fluid flush and change out, a tranny fluid 1x3, valve adjustment, cabin filter, air filter , oil change, Spark plugs, thermostat, upper and lower radiator hoses, valve cover gaskets, crank shaft gasket, cam seal gaskets, both intake manifold gaskets and I think that is it.
Gates thermostats - 33914 170* one
Gates water pump timing belt kit - tckwp329
Spark plugs 6 - izfr6k11
3 gallons type 2 honda coolant plus 1 bottle of royal purple ice coolant additive
3 bottle amsoil synthetic power steering fluid
Serpentine belt - 38920-RCA-a03
Crank shaft seal 91212-p8a-a01
2 cam seals - 91213-r70-a02
Cabin air filter and air filter - 17220-rda-a10. 80292-sda-a01
Intake manifold gasket first 1 - 17105-rcj-a01
Intakem manifold gasket second 1 - 17146-r70-a01
2 valve cover gaskets 12341-RCA-a01
2 bottles redline type f
1 bottle redline d4
Old Aug 6, 2014 | 03:08 AM
Mr24v's Avatar
2007 6MT TL Type-S
If you do decide to go aftermarket, keep in mind that there may be an increase in NVH.
Old Aug 6, 2014 | 12:56 PM
desakatao's Avatar
thanks for the info Sbarbee54. thats what am looking to do. do you know how much you spend in parts?
Old Aug 6, 2014 | 06:24 PM
Ryan_tl's Avatar
6th Gear
Thanks for the info too Sbarbee54. Just what I needed to start on my maintenance as well.
Old Aug 6, 2014 | 06:55 PM
EL BAN's Avatar
Nothing like OEM parts.. Did mine last week..
Attachment 105510
Old Aug 6, 2014 | 09:27 PM
crbnfbr's Avatar
You can pick a Gate's full timing belt kit with water pump for $130.99, You can spend $177.79 for AISIN kit. Which I've read they make if not all the Honda oem components, but a majority of them.
I personally have a $131.99 Gate's kit with 15k on it so far. Absolutely no issues. In fact my car seems smoother since the crank mark off of the cam mark.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
jmaxima03
Sep 27, 2015 10:22 AM
