100K miles
Old Apr 3, 2012 | 07:43 AM
tlorencz's Avatar
100K miles
This weekend I just rolled over to 100K miles with my 05. I bought it certified preowned with 48K on it. No major problems except ECU had to be reprogrammed once. I do the normal maintenance as recommended by the maintenance minder. I use Mobil 1. Have not had to do any brake work. Averaging 23 mpg combined city/hwy. Hope to go another 100K!
Old Apr 3, 2012 | 07:58 AM
losiglow's Avatar
Why did the ECU need to be reprogrammed?
SharksBreath's Avatar
BANNED
you've got the 105k service coming up. make sure you do that.
Old Apr 3, 2012 | 11:57 AM
tlorencz's Avatar
ECU had a problem that caused transmission to cut in and out at highway speeds. Kind of a freaky problem. I posted the problem and code previously. Engine would run and lights stayed on, but transmission wouldn't engage.
I take it in Monday for "B" maintenance. Check the brakes, suspension, transmission, rotate tires, etc. Timing belt and spark plugs should come up within the next 10K.
Old Apr 3, 2012 | 12:00 PM
spaceboy's Avatar
what exactly is "B" maintenance?
mada51589
Jan 9, 2025 04:40 PM
vaughanml2
Nov 1, 2021 10:16 AM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Legend2TL
Nov 20, 2015 07:31 PM
