'08 TL Hesitation Issues
Old Oct 9, 2013 | 10:52 PM
blaketeg's Avatar
5th Gear
08 TL base auto, 105k miles: Recent tune-up (oem plugs, filters, fluids, etc)
Been having an issues with my TL recently, no matter the temp outside, I have this hesitation/sluggishness that is very noticeable under acceleration. The car feels similar to a truck pulling a loaded trailer, like it wants to take off but something is holding it back. Some days, it will drive perfect with no issues and feel great. It will do this in 90 degree or 40 degree weather so temp is not a factor. Tried disconnecting battery to reset things with but no help. No check engine light either.
What could cause this? Any help is much appreciated. Everything I searched were 04-06 tl's. Just didn't see much with 07/08's having this issue. Thanks!
Old Oct 10, 2013 | 07:24 AM
LoveMyTL-S's Avatar
First of all welcome to AZ!!
The lag is normal, the stall converter(automatic clutch) engages fully at an RPM just above idle. That is what is causing the "lag".
Do you think it's more "lag" that this?
Perhaps resetting the ECU will help.
Old Oct 10, 2013 | 09:25 AM
96SC4's Avatar
Did it start after your "recent tuneup?"
Old Oct 10, 2013 | 09:58 AM
MarcoNorthPolo's Avatar
KCCO
Yes, try resetting the ecu and see if that changes anything. It always does for me.
Old Oct 10, 2013 | 10:11 AM
blaketeg's Avatar
5th Gear
Thanks! Glad to have joined.
Nope did it prior to tuneup. And this lag deffinetely doesn't feel "normal" because it drives perfect like it should some days. It gets to the point where I'm almost flooring it to keep up with traffic, a better way to describe it would be more of a surging. I'll look up resetting the ecu and see if that helps.
Old Oct 10, 2013 | 11:10 AM
LoveMyTL-S's Avatar
Good read here:
https://acurazine.com/forums/showthr...ight=ECU+reset
and here (long read):
Old Oct 10, 2013 | 11:40 AM
msala524's Avatar
08 TL-S NBP
disconnect the battery for 10 mins, see if that works
Old Oct 10, 2013 | 01:53 PM
BukvaMan's Avatar
It has something to do with the VSA mudulator under the hood. Mine is finally fixed. Im not sure what exactly went on but when i opened it up and checked for loose connections the problem fixed itself.
My car felt the same way for years... Now its like a dream.
Old Oct 10, 2013 | 02:45 PM
blaketeg's Avatar
5th Gear
Thanks for the replies everyone.
And BukvaMan, I was reading another thread that you had some input in and saw you replaced tons of sensors, a new battery, etc. I will certainly check into the VSA Modulator. Thanks for the input!
I've only owned the car for a few months and it has been driving me crazy.
Old Oct 10, 2013 | 02:56 PM
Blooze's Avatar
Check out the APP sensor as well...
Old Oct 10, 2013 | 04:14 PM
blaketeg's Avatar
5th Gear
Thanks Blooze I looked into it and the OEM part is around $135. I dont want to just throw a part this expensive at it and hope it fixes it. Has anyone else had an issue with this sensor going bad?
Old Oct 11, 2013 | 07:33 AM
Blooze's Avatar
It seems to be more common that I would personally like. I have an '08 as well and haven't had these issues. There are quite a few threads about it, including a DIY, and they all speak to poor, hesitant throttle response and/or choppy idle. The following is a thread from a quick search that was cross posted from the TSX group:
https://acurazine.com/forums/1g-tsx-problems-fixes-128/success-app-sensor-replacement-cured-p2138-non-smooth-accelerator-response-819824/
Old Oct 11, 2013 | 10:09 AM
ds03's Avatar
Reset the ECU. It should help for a bit until it 're-learns' some bad traits. Does well for me but will eventually degrade back to the hesitation and has to be reset again. Wish there was a long-term solution for this.
snorf
Nov 4, 2019 06:44 AM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
carz0159
Sep 20, 2015 06:11 PM
