'08 TL Base Transmission Replacement
Old Sep 27, 2011 | 07:28 PM
chefi84's Avatar
3rd Gear
Hi all,
It's my first post here but have been a frequent guest for the past few months while shopping for my Acura. Finally, after close to three months of shopping around I’m a proud owner of a 2008 TL base model with 68,300k (currently with 74,968k). I purchased from a private owner in Ohio. It was dealer maintained by previous owner with all history records in place.
A few pictures: http://www.flickr.com/photos/chefi_8...7627380371695/
Situation: It’s currently at my local transmission shop with a quote of $3,200 for transmission replacement with a 3-year warranty (Dealer quoted $4,400 for replacement).
Question: Has anyone in this forum been in a similar situation?
In a dark and lonely place right now.
Old Sep 27, 2011 | 07:39 PM
P1zzaman's Avatar
Originally Posted by chefi84
Hi all,
So.. you are saying that the transmission gave out completely? Or it was just shifting badly and they recommend a transmission swap?
If it's shifting badly, you may want to try a few things:
do a 3 x 3 flush with Type-F transmission fluid (the OEM Honda Z1 is crap to our transmissions)
replace the 3rd and 4th pressure switches.
But if the transmission is dead, then I am sorry...
Transmission reliability has always been an issue with these cars, but with proper fluid change and pressure switch changes at the right time, you will not have a transmission problem.
Once you get the new transmission, make sure you switch out the fluid to a Type-F fluid
Old Sep 27, 2011 | 10:42 PM
paperboy42190's Avatar
why replace the transmission? you can get it rebuilt for much less than that. i got mine rebuilt for 1000 less than your so called replacement. what are they going to replace it with anyways? used or new? rebuilding is the way to go, dont both replacing it.
Old Sep 27, 2011 | 10:50 PM
lilsid112's Avatar
Have you tried to get Acura to goodwill it?
Old Sep 28, 2011 | 07:40 AM
chefi84's Avatar
3rd Gear
The quote was for a replacement with a rebuilt transmission. They are trying to locate the part that needs replacement to simply repair it at a cost of 1k (approx), which is much better to my pockets but it's still a partial fix with the rest of the parts being left as is. The transmission is already out of the car.
Old Sep 28, 2011 | 07:49 AM
chefi84's Avatar
3rd Gear
Yes, I believe this was the best way to deal with this situation but out of Dealer phobia and the believe that this was going to be a simple fix, I decided that a Trans expert was the best way to go. Probably I shot myself on the foot here. But now I have to deal with the situation at hand. I can always tell the mechanic to re-install it but it will cost me additional $$ plus the fact that the dealer might detect the trans was already touched by an independent mechanic might not help my case. Three days without sleep and might have to get a loan to have it fixed.
I appreciate all your replies. It helps.
Old Sep 28, 2011 | 08:38 AM
sddale's Avatar
You are just outside the powertrain warranty and the car has been dealer maintained so you should call the dealer and see what they can do to help you out.
Old Sep 28, 2011 | 11:57 PM
acura_dipset_tl's Avatar
AM To WDP In My Garage
Damn sorry to hear.. Hope eveything works out for you.
if i would of known sooner i could of sold you an extra trans that i have from an 07 TL with only 32k miles on it for cheap.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
asahrts
Sep 4, 2015 05:55 PM
quake97
Aug 30, 2015 07:57 PM
