08 Tl Base Opening Hood While Drivng?
Well i thought about just pushing the front hood button and leaving it kinda open while driving so air can rush in cooling the engine,etc. I wont push the lever to open it fully so it will still be locked on. And of course when its raining or snowing it will be closed, just doing it in summer cuz engine gets a lil hot cuz of temps. Do u guys think i can do it, will it work and help with cooling a bit? I dont wanna do cai and other mods. Becuase if the 09 TL is all that ill trade in.
I'm gonna say no. The air can push the latch open (don't ask how) and the hood will fly up and nothing good can come out of it. I had a mechanic forget to put the hood all the way down on my truck, it was locked but not shut, and it came up at about 30mph and dented the hood beyond repair.
You have to think the aerodynamics wouldn't allow it and there would be too much pressure on the bottom side of the hood.
i cant say the same for motorcycles.
i will agree with the above statement about the force of aerodynamics. Be smart and dont ruin you car by leaving the hood propped open.
[edited by ggesq]
Dude, take it easy! We're all on the same side...and he was only asking a question. Chill...
As for the op's question, I agree with everyone else. Probably not the best idea, but I do have to admit, I've done actually done it a few times, but just as I'm entering my neighborhood - 15 mph max...don't ask why haha; no significant cooling imo (don't see heat rising or anything)
DO NOT do this! driving with the hood unlatched is asking for it to pop open and fold back onto the roof- its really cool! if you are the guy that owns a body shop,,, but not cooling~
the cooling of the engine is designed to pull air thru the radiator with its fans, past the engine and most of it dumps out under the car, Thats what all the plastic is for- routing air and making the radiator more efficient
If you are parked with the engine running and its 110 out- yes open the hood fully to allow heat to escape, CLOSE the hood all the way before you drive- turn the AC OFF if realistic
Go look at the hood hinges and rethink how much structure you lose when its open, dont drive it like that at all.
If your temp comes up more than 1 tick- most TLs run about 1-2 ticks below half- if it goes above half EVER- something is wrong- If it goes up and down something is wrong
I can drive ac on full, from sealevel 110 degre, to 6000 feet in the mountains where its still 90 degree day, and never see the temp needle move
With a main cooling fan and the ac fan, there should not be any cooling issues
Check the level in the radiator when dead cold-must be all the way to the top
and check the res bottles hose is still attached inside its cap.
How many miles/years on the water pump and coolant?
Here's the warning to the three flamers above and you know who you are. This isn't fucking ramblings. If you want to go flame someone go do it over there. Is it something I would do- no- but if I have nothing positive or constructive to add I'm not going to post. Some of you guys have been here a while and you are well aware of the rules for posting. Either stick to it or your going on a vacation.
Air flow will not go thru the proper way and create more drag. Please do not do this.
didnt someone say that a lot of the cooling comes from under the car too...thats why we shouldnt remove that plastic thing that hangs down and scrapes when you enter a steep drive?!?!?
so no, dont drive like that!!!!
Popping the hood will also creat a lot of drag and noise. You might as well remove the hood if is the route you want to go. But as far as cooling, the car is already made to cool itself. No need to pop the hood.
Well i just bought it in march of 08. I think it almost has 2,000 miles. Do i have any thing to check for. And u know that silver cap infront of the engine i can barely see any fluid in there. Btw i removed the plastic coverings in the around the engine area. And the reason i wanted to cool the engine more b/c some guy said heat was the #1 factor killing the performance in our car"the guy that did the TL DIET said that".
i dont think it is so much the heat around the engine, but the hot air being sucked in to the engine. thats were a CAI, TBS, and non-heat transferring gaskets help out.
To the OP you are unbelievable. I responded to your is the tl-s that much better then the tl thread along with your burn out thread and now a thread asking if you can drive your car for added performance with the hood opened. I think I will ban myself.
Yes please don't drive around with your hood half open. It's extremely dangerous. Get a CAI, TB Spacer and thermal gaskets if you're that worried about under hood temps, and if you're not willing to modify stuff just remember that the car was designed the way it is to operate well from the factory. You're not going to overheat unless something fails.
Want to run cooler?
I don't think running with the hood opened even a little is safe. If you want to run cooler. Use this, I do....
http://www.redlineoil.com/products_coolant.asp
You've got to be kidding me.
The engine is designed to run at a certain temperature (usually about 180F right?). A thermostat in the cooling system restricts coolant flow most of the time to maintain that temperature so you're never using your cooling system to 100% capacity anyway. All that will happen if you open your hood while driving is that the thermostat will further constrict coolant flow to compensate for the additional air flowing over the engine.
Poping the hood while driving to keep the engine colder has got to be the stupidest idea I've ever heard.
If you still feel you need to do cool your engine then I have two ideas.
You can take the hood off the car and store it somewhere safe.
You can also get a carbon fiber hood and have a hood scoop put on.
Originally Posted by sol_da_man
you should try removing one of your wheels. not the spare one only, but also one of the rear ones. since the TL is front wheel drive, the extra rear wheel and tire yo have spinning creates rotational mass. we all know that we need to unleash the full raw potential of the TL by removing ANYTHING that can be considered excess. ANYTHING
Originally Posted by say when
I feel like I am on forum with little boys. The OP deserves a flame this could be one of the most immature questions about a car I have yet to read. Give us a break. And to the mod for giving the warnings... thanks for the using such great language. What an example to these boards you are. I'm sure my comments will be erased and I will be banned. Some mods are like the CHP a little power and wham a tool is formed.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
09-17-2015 09:01 PM
