08 steering wheel removal
7th Gear
Anyone have service manual scans for removing the steering wheel from an 08? I found some floating around for 04-06, but looks like they changed it starting in 07 and up.
BUSHWICK BROOKLYN
can you send me the 04 - 06 ive been looking for those. i would really appreciate that.
im trying to upgrade mine to a type s. thanks in advance
Registered User
just about all steering wheels from all make/models of cars are the same.
remove the access panel, and disconnect the airbag connector, remove the screws holding the airbag (in this case 2). disconnect any other cables in the center to the cable reel. remove the center bolt, and pull the wheel off. sometimes you will need a special tool.
Registered User
Originally Posted by Tripnbeats
yea u def need a puller for the wheel......i changed mine because of wear and its really pressed on there.
