07 TLS Lower Fog Bulb Replacement
Hey fellas, I've been doing some reading and the majority of the fog posts I see are the replacement for the upper fog bulbs in the headlight unit. Does anyone have a decent DIY or scans for the replacement on the fog bulbs in the lower grille on the Type S? Am I able to just access them from behind the wheel liner?
I picked up some yellow Nokya bulbs, and I'm going to throw those in there. Thanks in advance.
No need to jack the car up or remove the wheel. Just turn the wheel all the way to one side and take the 2 clips out from each wheel well lining. After you complete one side, turn the wheel the other way and do that side. Very simple just changing out bulbs...
AZ Community Team
Received 7,771 Likes
You have to unclip the wiring connection before you can turn the bulb to remove it. It's a little tricky the first time because you're doing it by feel.
Pretty sure there are instructions in the Owners Manual for replacing our fog lights.
Also you can look for Pics/Service Manual scans in the 3G Garage: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
