07 pcm in 06 transmission help
I bought A 06 tl automatic, that had fire damage, but not bad. Had to replace pcm, and immobilizer. Could only find a 07. Problem I'm having now it's the 07 has 4 shift solinoid vs 3 in the 06. Any way I can still use this pcm? It a way to program the 06 firmware to it?
It's highly likely that the 07 PCM will not work even after they try to put the 06 software on it because it's not designed for that configuration. It's your time. Your money. Your choice. 🤷♂️
hostage46
04-14-2006 08:37 PM
