07-08 Rear ANTENNA FIN
2004 TL !!
where can i buy the antenna, or something that looks the same... it doesnt hafto be working, i just like the look and i wanted to place it on my 04 TL since i have 07-08 base tail lights.
that thing on top of the rooof...
http://www.acuraoemparts.com/delray/...All&vinsrch=no
looks like you need #7
idk what color you need tho
Uhhh I thought all TL's have the roof mounted XM antenna? My 04 non-navi does.
If you just want it for the look why go through removing the the headliner and drilling a hole in your roof. its not like you are going to run wires inside the car. Just use 3M double sided tape. If a spoiler can be mounted with that i am sure this little antenna will survive. just my
That's the XM radio bubble, not the navi antenna...
Just fyi, headliner does NOT need to be removed to r&r the roof antenna. Just remove the rear upper brake light and rear maplights and you can access it perfectly fine with an open ended wrench. Been there done it when adding the 07+ navi and had to swap roof antennas....
No you don't. People always make it sound like it's a lot of trouble, time and money to do it but it's nothing compared to installing the factory Nav system. That took alot of time and money and patience. Drilling a hole is what 5-10 minutes.
IIDXholic
10-08-2015 07:53 AM
oyayjoe
09-12-2015 04:40 PM
