04 TL -Rear Left Taillight Replacement Hints?
HELP - I have a replacement left rear taillight for my 04 TL but I am baffled on how to install it. I am planning on buying a repair manual but would like to replace this taillight tonight or tomorrow. Any help would be appreciated. Thanks in advance for any helpful insite.
This thread will help you. https://acurazine.com/forums/showthread.php?t=109191
You can get the service manual here.
http://www.helminc.com/helm/Result.a...DSHD8TJJE81VS5
There's no need to remove the bumper...simply loosen one side. Pull away the trunk liner (a few pins and an unscrewable knob), loosen the 4 nuts holding the studs, unclip the wiring harnesses, and you're there.
There are 4 screws holding the LED board in place. Unscrew those, pull it slightly away from the housing, unclip the 3-pin connector, and it will easily come off. Take off the old harness and clip it on the new housing. The rest is self explanatory.
cycdaniel
12-17-2019 10:58 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
