'04 TL Headlight Issues
Does anyone know of a good low cost aftermarket replacement for the 04 HIDs with ballast, ignitor, and bulbs?
Also, my daytime driving lights are out. My left has been out for roughly a month and the right went out this past week. I replaced the bulbs but still nothing. Aside from fuses, what should I check next to diagnose?
Thanks!
Thanks!
the retrofit source has a plug and play morimoto kit with everything, ive been running it on my 07 for a few months now and no complaints.
... i just checked for a link for you but apparently they dont have it anymore. they still have the bulbs/ballasts/igniters since that stuff is basicalyl universal, but they used to have honda/acura plug n play adapters so you would plug it directly into the stock plug on the harness, and that part i dont see anymore. maybe you can call/email them about it
they do have oem replacement ballasts too, not sure if they have the ones for the tl... i think its the mitsubishi's though
When you say the ballast wasn't an exact fit do you mean dimensionally or is it not electronically compatible? Thanks.
So I called The Retrofit Source and they confirmed that this is the correct kit for a 2004 TL:
https://www.theretrofitsource.com/matsushita-mitsubishi-hid-repair-kit.html?preselect=49455%2C51988%2C50305
Does anyone know which bulbs or ballast adaptors I should choose?
thanks!
thanks!
stick with the pre-selected
double sided tape or just bolt on
