'04 3G TL 6MT Squeaking Question
Ive got an 04 6mt. Ive had a squeaking noise at idle for a bit. Definitely sounds like something rotating at relative rpms to the engine. I just noticed today that when i put the clutch in, the noise disappears. AZ is always my first stop for help...... and always right too. Any 6MTers deal with this?
Not sure enough yet if this is specific to the TL but it sounds to me like the Pilot bearing (clutch) or Throw out bearing (transmission) Especially if you push the pedal in and it goes away.
How many miles? OEM original clutch?
^ +1
It'll shift fine and you can most likely ignore the bearing noise until you do the clutch.
When you replace the clutch, the kits come with the pilot bearing anyway. Input shaft bearing however is in the trans.
thanks so much for the help. i quickly glanced at your answer months ago, and forgot to reply until now! thanks again and AZ to the rescue as always!
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
rboller
09-23-2015 02:49 PM
