04-06 A-Spec Install Help Please
Hello Guys New member here and have started mods already. I just baught a used A-spec front lip off ebay for $130 but doesnt have any hardware. I have tried a bunch of searches and found acura doesnt sell the hardware. There were a few who said they done it with out the hardware. Being a newbie how can i put the a-spec on without the hardware? I know the bottom is just 10mm bolts, but what about the center "post lock" and the ends where it goes in the wheel well mount to with out that bracket. Also is it best to take bumper off? I seen one meber did and one didnt on my searches. Any help would be great. My other mods turned out great to az iv done the ebay spoiler leds interior and cup holders so far
Kit should have the hardware, especially the brackets as it would save a lot of trouble.
Acura instructions:
http://photos.imageevent.com/astrobo..._front_lip.pdf
From the 3G garage:
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-spec-body-kit-installation-3g-garage-e-002-a-612659/
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-07-tl-spec-front-lip-install-3g-garage-e-002-a-624436/
https://acurazine.com/forums/3g-tl-2004-2008-93/fixed-bodykit-gaps-w-3m-scotch-heavy-duty-foam-tape-553292/
Try the dealer for the hardware.
Here's a start:
90103-SDA-A00 ACURA TL TAPPING SCREW (5X20) 2006 TL 0.53
90331-SD5-003 ACURA TL SPRING NUT (5MM) 2006 TL 0.83
91503-SZ3-003 ACURA TL BUMPER CLIP A 2006 TL 3.03
91503-SZ5-003 ACURA TL BUMPER FACE CLIP 2006 TL 3.03
93903-254G0 ACURA TL TAPPING SCREW (5X20) 2006 TL 1.60
Acura instructions:
From the 3G garage:
Here's a start:
I tried the dealer but they dont offer the hardware you have to buy the whole kit. But i figure there has to be a way im sure these things break wear or something so that someone may need it to replace it.
try acuraoemparts.com
is the bracket for the front wheel wells the same bracket for the mud flaps? i seen a video for taking off rear bumper and bracket looks close to the a-spec mounting bracket i seen. does any one know if it is the same?
Former Sponsor
Actually it is. You need the bracket for the sides will fall/droop down. You can try really high strength tape on the sides and it will hold it up. Try to make your own bracket. The bracket goes into the wheel well and acts as a lip to hold up the a spec. Maybe a 2 inch screw with a spacer in the middle?
Acura instructions:
From the 3G garage:
https://acurazine.com/forums/showthread.php?t=612659
https://acurazine.com/forums/showthread.php?t=624436
https://acurazine.com/forums/showthread.php?t=553292
Here's a start:
Acura instructions:
From the 3G garage:
Here's a start:
Good luck with the install, I am planning on doing this to mine eventually
1. Buy piece of metal.
2. Bend the shit out of it.
3. Drill holes.
Bracket made.
3. Drill holes.
Bracket made.
na havnt installed it yet, but i deff will let you know, extra hands come in handy some times esp. if you have done it before. I seen a couple people on here from richmond but never seen there cars driving around.
Registered Member
Your gonna have to ask others if they will still work, but I have 2 hardware kits for a 07-08 aspec type s front lip. If the brackets are the same you are welcome to them.
If you need a pic of brackets lmk
BoricuaTL
04-08-2016 01:08 PM
nuldabz
09-03-2015 05:49 PM
