* 6 SPD tranny fluid change * 3G Garage #C-013
#82
But that fill bolt requires a lot of force to get it loose, even when torqued to spec. It will make a very loud "pop" sound when it breaks loose. I thought my swivel had snapped, but it was just the plug breaking looses. It's been the same each subsequent time I've removed the plug: lots of force then all of a sudden a loud pop which will scare the crap out of you if you're not expecting it.
#83
I have never removed the check plug because, well you really don't need to if you make sure the transaxle case is level and you refill with 2 quarts 10 ounces of the good stuff.
If you take your time, go slowly and carefully (so you don't pour to fast and get a back flow when filling), this job will take about one hour. The actual drain and fill takes around fifteen minutes. This is the easiest and least messy manual transmission drain and fill I have ever done on any of my previous cars. And you do not need to remove any of the items previously mentioned such as the engine air cleaner housing, the flexible ribbed throttle body coupling, or the battery and tray. With ratchet extensions, a socket swivel, a remote pickup tool, and a long neck funnel, you can reach everything you need to reach.
#87
I changed my transmission fluid and I gotta say for my first time.. Damn that was easy. Fill till it comes out the sight hole. Dayum. Haha. The top fill hole had to be taken off by the previous owner, because it came out with not TOO much oomph. But a nice trouble free change. No leaks and I even reused the same washer. Though next time I plan to replace it. And upon putting it in reverse I could tell a difference. I can rev match also now unbelievably easy without the tranny feeling clunkyish. That stuff did the job. I plan to keep this in there about 15-20K then do another change.
And if the GM stuff is unavailable or out of production anytime.. I will switch to Redline since I hear so much about that too.
#88
It is done in Automatic cars. Means pretty much change the fluid and refill 3X. The 3rd time being the final fluid. It's easy. Drive your car for the 1st time for a little. Come back. Change it. Drive your car again. Then refill, then your done. :P
Though on manual's it is not really recommended.
#91
Well, it was one month today that I swapped to the GM fluid. I have not had one single occurrence of the shifter popping out of third or grinding in any way. NOT A SINGLE TIME!!!!
Before it would happen several times a day.
Just amazing that a fluid can make such a physical difference. Do it!!
#93
I ordered 3 qts of this "magic juice" last week, and it should be arriving some time tomorrow. I figured I would just have a shop do the drain and fill since I don't own a torque wrench, but I called around asking for quotes today and they were obscene. $80 just for labor seems pretty steep to me... I guess that means I'll pony up for a torque wrench and have some fun doing it myself.
Can anyone recommend a good (and relatively cheap) torque wrench for the job?
I also have a novice question about jacking: With the front of the car on jack stands and the floor jack in the rear under the tow hook, is it safe to work under? Or do I need to invest in a couple more jack stands or some ramps?
#94
Sears makes some good quality torque wrenches. that being said, I got mine from harbor freight.
I think the scenario you described is "safe enough." I would highly recommend getting two more jack stands though.
#95
YES, YES, YES
#97
Jackstands on one end with the wheels chocked/car in gear/p-brake pulled on the other end (on a level driveway/garage) is fine.
#98
I use ramps for the front wheels with my car pointing away from my house in my driveway. The driveway has a slight downward slope. Then I use a floor jack on a 2"x10"x3' board (protects my driveway) to raise the rear at the center jack point just a few inches to level the transaxle. My ramps are homemade and are quite strong and much better than the typical Rhino plastic ramps you find at AutoZone type stores. This works great for my purposes.
And yes, never get under a car that is being primarily supported by a floor jack... or any jack for that matter.
#101
#103
#104
So one other question: my TL's transmission is still under warranty. I want Acura to change the syncros, but they won't do it unless they witness it. Of course, you can never get it to do it with a mechanic in the car. I should probably wait to do it and keep trying to video record when it happens? I'd love to hear any other suggestions.
#105
Thanks. I think that I already knew the answer, I just needed some validation. Cheers!
#106
Do you know offhand what the TSB number is? I'd like to give it a read and see if it requires that a tech actually witnesses it happen.
#107
TSB Number: 08-018 NHTSA Number:10026204 TSB Date: July 18, 2008 Date Added to File: October 7, 2008
Failing Component:
Power Train: Manual Transmission
SYMPTOM:
The 6-speed manual transmission grinds when shifting into 3rd gear, pops out of 3rd gear, or is hard to shift into 3rd gear.
NOTE: These symptoms can be intermittent and sometimes more noticeable in colder climates.
PROBABLE CAUSE:
The transmission has a faulty 3rd gear synchronizer or 3-4 shift sleeve.
CORRECTIVE ACTION:
Replace the 3rd gear set.
#108
^^Thanks for that. Well, I emailed the local stealership and forwarded the TSB. The argument I was getting was that they need their tech to witness it happen. And for $57 of diagnostic time, they did eff all. I feel a bit cheated that they charged me even that, given that I diagnosed it.
My argument back was that since the TSB states that the problem can be intermitant (as mine is), that it is a tacit admission from Acura that a tech may not be able to reproduce the problem at will. We'll see what I get back from them.
#110
Just look at the pictures in the first page of this thread.
#111
And IF you remove the check plug, which is not at all necessary for the drain and fill, make sure you use a torque wrench when you re-install it, set to 8.7 ft/lbs. Several members have not done this and have tightened it to the point of wrenching the head off of the bolt. Does not make for a happy camper.
Be smart. Either don't remove it at all or if you do, use a torque wrench.
#114
https://acurazine.com/forums/showpos...3&postcount=13
#115
Correct. But you do not need to remove it to do a proper drain and fill. Just make sure your transaxle case is level (use a carpenter's level), then refill with 2.3 quarts (U.S.) of your chosen fluid.
#116
Awesome thread - just changed mine this morning without any issues to speak of and took for a quick spin around the block - silky smooth right away. VERY much improved.
I disconnected and removed the top of the air filter box (4 screws, 2 hose clamps) and didn't even have to use a swivel to loosen up the fill plug - just had a long extension and was able to get a straight enough angle on it.
#119
Found this http://www.acurapartswarehouse.com/P...gPicture=False
Can you reuse the old washers? just flip them?
#120
The transmission drain plug and the oil pan drain plug use the same aluminum washers. The transmission fill plug's washer is quite a bit larger. Don't forget to use a torque wrench: 29 ft/lbs for the drain plug and 33 ft/lbs for the fill plug. If you choose to remove the check plug, that one takes 8.7 ft/lbs.
