water in tail lights
Old 01-30-2017, 09:08 PM
pcloadletter's Avatar
Is this a first?
Old 01-30-2017, 09:37 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
Although I have seen this in other cars, the RLX Owner's Manual states:
The inside lenses of exterior lights (headlights, brake lights, etc.) may fog temporarily
if you have driven in the rain, or after the vehicle has been run through a car wash.
Dew condensation also may build up inside the lenses when there is a significant
enough difference between the ambient and inside lens temperatures (similar to
vehicle windows fogging up in rainy conditions). These conditions are natural
processes, not structural design problems in the exterior lights.
Lens design characteristics may result in moisture developing on the light lens frame
surfaces. This also is not a malfunction.
However, if you see large amounts of water accumulation, or large water drops
building up inside the lenses, have your vehicle inspected by a dealer.
Have you had a lot of rain lately or high humidity followed by temp change?
The following 3 users liked this post by TampaRLX-SH:
hondamore (01-31-2017), justnspace (01-31-2017), pcloadletter (02-06-2017)
Old 01-31-2017, 06:31 AM
Received 16,260 Likes on 11,971 Posts
most tails are not completely sealed
or you may have a crack in it.
or the owners manual may be correct
Old 02-06-2017, 07:11 PM
It has been raining, snowing, but it's likely a seal. Had the same problem on the S2000, a little silicone resolved the issue.
