RLX2019 "ready" problem? F to C conversion?
I observed my READY lamp is ON even car is cold. Is it normal? I remember READY lamp goes ON when blue C lamp is off. What do you think?
I read thread about changing C to F from some MDX but there is no solution in this case., How do you think, is it possible to change these units? Re-programming is possible or i should buy canadian modules? I'm fine with gauge cluster but i can't stand F in center console and beetwin gauges.
The “ready” indicator comes in as soon as the engine turns on and indicates “ready to drive”. It’s always on.
To change units, go to System Settings, then Other, then Units. However, this will only change you from mph to kph. You can also change from mph to kph in the HUD by using the MID settings. No temperature conversion, sadly.
DanL07RL (12-07-2022)
jproy
02-19-2009 12:03 AM
