DRL operation
Old Nov 17, 2014 | 10:36 PM
scv76's Avatar
DRL operation
I don't think my DRL's are working properly. When the switch is in Auto, they low beams never switch over to DRL even in the middle of the brightest day
From page 140 of the manual:
The low beam headlights come on slightly dimmer than normal when the following
conditions have been met:
• The power mode is in ON.
• The headlight switch is AUTO, or in .
• The parking brake is released.
The low beam headlights return to the original brightness once the headlight
switch is turned on, or when the head light switch is in AUTO and it is getting
darker outside.
Daytime Running Lights U.S. Models:
The daytime running lights come on dimmer when
the headlight switch is in (the position of a symbol that looks like two lamps) than when it is in AUTO.
In AUTO, if the ambient brightness is dark,
the low beam headlights come on.
Anybody else have this problem?
Old Nov 18, 2014 | 08:35 AM
George Knighton's Avatar
Grandpa
I don't really think of it as a problem, but it does seem to me the lights are pretty much just ON during the day.
The car was delivered with the switch on Auto and the fog lights On, and I've never bothered to do anything with it since it works just fine for me.
But...now that you mention it, the low beams do not seem to be dimmed in my configuration.
Old Nov 18, 2014 | 08:36 AM
Grandpa
At least they're using low beams for DRL now. Even though they were dimmed, when people were using the high beams for DRL, you'd still annoy some people.
Old Nov 18, 2014 | 03:27 PM
acuranj18's Avatar
I have no problems at all with the switch set to auto. The low beams only come on when it's dark. At first I thought the low beams were always on because the DRL's are pretty bright.
Old Nov 18, 2014 | 04:07 PM
Grandpa
Maybe that's what I'm seeing, too.
Old Nov 18, 2014 | 04:11 PM
hondamore's Avatar
It seems that the DRL is another feature that helps the Jewel Eye "shine" (pun intended) and exceed other headlight systems.
The whole purpose of DRL is to make the vehicle more visible to other drivers and the wide dispersion of the Jewel Eye maximizes this effect even on less than 100% power. With older systems that use the high beam bulb on a lower power setting, that bulb is focused into a high, narrow beam straight ahead of the car meaning that it has the potential to be too bright for oncoming drivers and at the same time all but useless/invisible for cars outside that narrow beam. Conversely, if you find yourself in the blind spot of another car, the broad dispersion of the Jewel Eye DRL will provide a little flicker of light to the side of your direction of travel that could mean the difference between the other driver seeing you and having no idea that you are there.
Kudos to Acura for a very clever system.
Old Nov 18, 2014 | 07:46 PM
holografique's Avatar
Speaking of fog lights...we have yet to see ANY pictures of the RLXh LED fog lights in action. Not even Acura has any pictures posted with them on...(not surprised).
Any of you lucky bastages care to post us a pic of your pretty little LED fogs?
Old Nov 18, 2014 | 10:49 PM
4WDrift's Avatar
The RLX is the same as the TLX, right? IIRC what I saw once, the TLX DRLs are the top edge of the jewels (3 or 5?). The lows are the full 3 outer and the highs the 2 inner. Hard to notice the slight difference.
Old Nov 19, 2014 | 07:31 PM
Grandpa
This doesn't help much, because I didn't remember until it was quite dark.
I don't think they even do much good, but somebody else here thinks they do exactly what they are supposed to do.
Perhaps my problem is that I'm old enough to remember that they used to be called auxiliary driving lamps, and used to provide a very decent amount of illumination. :-)
Old Nov 20, 2014 | 08:15 PM
Thanks George! Whenever you get a chance, I'd love to see a slightly farther off shot and front center. just to get a sense for the difference in front lighting presence the car has when it's coming at you from a distance.
Old Nov 22, 2014 | 11:07 AM
neuronbob's Avatar
Here's a morning shot from earlier today. Lights are fully on (i.e. not DRLs; switch is on "ON", not "AUTO". I'll try to get a night-time shot later. Note that the LED foglight is a single "bulb" on each side.
Old Nov 22, 2014 | 11:10 AM
perfect shot bob! and it looks great! has a well balanced look to it when approaching you.
No worries on the night shot. I actually prefect day time shots with the lights because it helps you get a better perspective of how the lights look as it relates to the rest of the body, which is difficult to see in night shots, not to mention CBP at night
Hope you're stayin warm up there!
Old Nov 25, 2014 | 08:52 AM
db22's Avatar
I do not understand why the rear lights are not on as well as the front when DRL's are called for. Many countries now require rear DRL's as well and so should the USA.
Old Nov 25, 2014 | 09:10 AM
Zoommer's Avatar
On a dark night and on a street with little illumination I can tell the difference between the fog (shouldn't they be yellow if true fog lights?) lights on and off--when on the dispersion pattern illuminates the sides and maybe 20 feet in front of the car. I have not checked if the fog lights turn off when the brights are on.
Old Nov 25, 2014 | 04:30 PM
Malibu Flyer's Avatar
The Fog lights do turn off when the brights are on. The reason is that in fog you do not want to be using the brights since they will primarily illumaniate only the fog. The purpose of fog lights is to light the area close to the ground where the fog will least liklely exist.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
joflewbyu2
Oct 8, 2015 11:16 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
AcuraKidd
Sep 25, 2015 11:18 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
