2020 Acura RLX SH-AWD Transmission System Problem.coupled w/ a blind spot info system
SubscribeWTF! 2020 Acura RLX SH-AWD Transmission System Problem.coupled w/ a blind spot info system problem! The car has just a little over 20k miles on it everything has been serviced at the correct times & intervals a yes I changed the rear differential fluid right before I reached 15k miles! It’s got to be an electrical or software issue bc I don’t notice so much as a hitch in the transmission while driving. I haven’t scanned it w/ my nice scanner yet but I’m not getting code from the Fixd app. Any thoughts or suggestions would be greatly appreciated. Thank you in advance for your time & effort!
hondamore
close
- Join DateMay 2005
- LocationWestern Canada
- Age65
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,021 Times in 544 Posts
Myself and others have experienced such warnings in the MID when the 12V battery was in need of replacement. It might be worth a trip to the dealer to have your charging system checked out.
Even if you drive the car frequently, the car may have sat on the dealer lot for a long time and normal parasitic loss to the battery may have weakened it.
Good luck figuring things out and getting back to enjoying your Sport Hybrid.
mrgold35
mrgold35
close
- Join DateJun 2006
- LocationABQ, NM
Liked:1,657 Times in 1,281 Posts
My OEM 12v battery went bad on my 18 RLX Sport Hybrid Dec/2021 with 19,000 miles. I had "U0104-00 ACC may not work properly with baking system" and "U1100-Gauge control module loss of communication". Acura replaced the battery (with OEM) and cleared the codes. I've been A-OK since with +28,000 miles.
rlx015
close
- Join DateJun 2011
- Age46
Liked:288 Times in 206 Posts
After owning 06 Acura RL for 11 years, one thing I learned is that if 12V battery is older than 2.5-3 years, and some gremlins start to get noticed with the car - step #1 is replace 12V battery... then go from there
