Stiff Power Steering
Old Jan 11, 2022 | 01:41 AM
AcuraAreDeeEx's Avatar
The steering on my 2019 RDX A-Spec suddenly became much stiffer especially when making turns in the past week and I'm not sure what the issue could be. It's been snowing and its been pretty cold where I am but I doubt that would be a cause...
Any help would be appreciated.
Thanks!
Old Jan 13, 2022 | 07:42 AM
Type X's Avatar
OG
Thanks!
Tire pressure adjusting with the temps?
Old Jan 13, 2022 | 08:06 AM
Leaf 68's Avatar
Frozen snow in wheel well & mud flaps?
Old Jan 13, 2022 | 11:40 AM
Funz51's Avatar
Expanse me
in Sport mode?
Old Jan 13, 2022 | 01:24 PM
Nope, snow and ice has all melted where I am now and its still hard to steer especially at low speeds and when trying to park.
Old Jan 13, 2022 | 01:25 PM
It's currently at 36 PSI when cold and warms up to 37.
Old Jan 13, 2022 | 01:28 PM
Originally Posted by Funz51
in Sport mode?
Nope, sport mode is unbearably stiff. I have to drive in comfort mode just to manage. Not sure if recently installing a hardwired dash cam or having my tire patched up from being punctured by a nail are factors, but I also have no warning lights showing in the dash.
Old Jan 13, 2022 | 05:37 PM
Funz51's Avatar
Expanse me
if you were in the fuse box, double check you did not Disturb the fuses.
Old Jan 18, 2022 | 07:12 PM
I brought my car back to the shop I had my dash cam installed and they couldn't figure out the issue. Any idea if they had the fuse tapped correctly? This is for the Thinkware Q800 Pro 2CH dash cam.
Old Jan 18, 2022 | 08:44 PM
Funz51's Avatar
Expanse me
I would start with removing the tap and just put the fuse back in. Leave cam off. Remove the negative on your battery for a few minutes, reconnect and test drive, just a suggestion.
also, look at the Honda service site or your manual at least and check any fuse that has anything to do with hydraulic, steering, etc. sounds like the hydraulic pressure is low, or rather the fuse to that hydraulic relay, etc.
Old Jan 18, 2022 | 09:02 PM
sonyfever's Avatar
Why don't you visit the dealership? The car is still in warranty. Power steering unit is well instrumented that if anything goes wrong, it should throw a code to precisely tell the mechanic where the issue is. I think the chance of electronics failure in the EPS without code is unlikely, but you did not mention any warning message, so something does not sound right. Could it be a mechanical issue? Well, I would argue if it is, you should experience more issues in addition to heavy steering. Again, I would urge you to visit the dealership. After all, if EPS suddenly fails without any code when you are going into a corner, you are doomed. Don't take chance with your own safety!
Old Jan 19, 2022 | 12:52 AM
1stRDX?'s Avatar
From the 2019 Owner's Manual, page 619 - It appears the tap is in the location for the VSA (Vehicle Stability Assist) circuit.
fohan
Nov 22, 2023 11:19 AM
Nate Washington
Apr 19, 2019 07:14 AM
jcross1231
2G RDX Problems & Fixes
Aug 13, 2016 08:18 AM
mav238
1G RDX (2007-2012)
25
Feb 10, 2015 10:14 PM
paneerlovr
Dec 23, 2013 05:36 PM
