Heated Steering Wheel does not stay warm
Old Jan 24, 2019 | 06:26 PM
mamat's Avatar
8th Gear
I have an A-Spec and added the Heated Steering Wheel option. It heats up immediately, but seems to cycle from heating and cooling down. The heat is never consistent after the first minute of heat. It was 20 degrees the other day and when I turned on the heated steering wheel, the heat was immediate, but the wheel cooled off even before the car was up to temp. I find myself constantly moving my hands searching for the next heated spot. Is this normal for Acura's? None of our other vehicles with heated steering wheels cool down until the wheel is turned off. The dealer told me it is normal and works like the rear window defroster. Not sure why I paid $600 for a heated steering wheel that is only heated some of the time.
My navigation also does not take addresses, verbally or physically entered. The tech sat with us in an A-Spec the dealer had on the lot and it's navigation did the same exact thing. So I was basically told that this is normal...normal....are they kidding...what is the point of navigation if is does not navigate?
Thanks for any help or suggestions with this!
Old Dec 11, 2019 | 01:26 PM
Jamessage's Avatar
5th Gear
Feel the same situation. 2020 Aspec
Old Dec 12, 2019 | 07:11 AM
mamat's Avatar
8th Gear
My info system was not working either...took a big hit and traded it in for a Stelvio, Alfa Romeo. Hope ur issues get worked out.
Old Dec 12, 2019 | 08:39 AM
EFR's Avatar
EFR
Nope. Mine is a 2019 ASpec I added it to, but works great.
Old Dec 13, 2019 | 12:30 AM
XMDXernowRDX's Avatar
Not normal on either count in my experience. I have a 2020 Tech on which I added a heated steering wheel. It stays warm and I usually end up turning it off manually.
Verbal inputs for navigation also work fine.
Old Jan 28, 2020 | 09:32 AM
er97ic's Avatar
EFR- When you add a heated steering wheel to the ASpec, is it the same style wheel or is it the advanced wheel? If I understand correctly, the ASpec wheel has a different leather pattern and stitching. I assume the paddle shifters are separate from the wheel and don't get changed? Thanks!
Old Jan 30, 2020 | 11:14 AM
mamat's Avatar
8th Gear
So sorry, I actually never checked or took notice. Unfortunately, Acura could not fix the bugs out of my info system and we had to dump a year old car! I loved it, but the emergency braking warning would come on when it shouldn't, maps didn't work and apple car play stopped working. They would reset the system only for it to go glitchy again. Hope you have better luck with yours.
Old Jan 30, 2020 | 05:22 PM
Midwestuser1's Avatar
I have the ASpec and I added the heated steering wheel. It is the ASpec style wheel with the heating element added. I believe they reuse the paddle shifters when they swap out the OEM ASpec wheel with the heated one.
Old Mar 10, 2020 | 11:36 AM
DJA123's Avatar
2020 RDX, Advance, AWD
Traded an Acura for an Alfa to get away from problems. Surely, this is a low point in the lifecycle of the Acura brand.
Old Mar 10, 2020 | 04:39 PM
EFR's Avatar
EFR
Yes, same ASpec wheel and style
t55J$via
3G RDX (2019+)
Dec 3, 2019 12:41 AM
accord98
Oct 23, 2017 10:18 PM
3gstealth
Apr 8, 2011 06:38 PM
MiaQbn23
Aug 27, 2009 05:45 PM
MilehighTL
Aug 24, 2004 07:38 AM
