Brake squealing
#201
I had my state inspection done this morning at my dealership and asked about it and was told there was a fix that was released earlier this week. They will have to order the replacement front rotors and I have it scheduled right after Labor Day.
#202
#203
Well after almost a year with the upgraded pads I installed that did eliminate the noise.....it’s back. It’s only started to creep into the 50’s here at night but on the morning when I leave for work at 5am I am letting the whole community hear the song of my brakes. It’s beyond embarrassing. Not sure what route to take, my service manager is awesome and a car guy himself so I’m sure he’ll take care of me just not sure what he’ll be allowed to do. I’ll keep you guys updated.
#204
Is the rotor replacement in conjunction with the squeaky brakes or separate? Do your brakes wobble under load? Do you have a picture of your service statement for the aforementioned replacements?
#205
Gearhead
I have a growl/grinding, possible a little squeaking and it just seems to come from the left rear only. It starts under mild application of brake, goes away when I brake harder but it worse when making a left turn. It almost sounds like when you the pads down metal to metal. I haven't taken it in yet but it has been helpful to read this thread.
#206
5th Gear
Squealing brakes fix...
I had the squealing brakes on my 2019 Adv RDX. The pads and rotors were replaced twice but that only fixed it for about 1500 miles. Dealer said they all do that and Acura knows of the problem and might have a fix by the end of the year. I called Acura customer care and was told the same thing. I explained that this is unacceptable and spoke with a supervisor. He said he would get back with me in a couple of weeks. He did call me and said they have a fix. It is the rotors causing the problem. Acura was coating the rotors with something to prevent corrosion and this coating caused the squealing. He called my dealer and authorized a pull ahead order to get the new rotors and put them on my vehicle. There is a service bulletin being written/issued to address this. So far the brakes are nice and quiet. I would contact your dealer, tell them about this, and see if they can order the new rotors.
#207
#208
5th Gear
Did they put on the "new" rotors without the coating? It is my understanding these have only become available in the past week or so.
#209
#210
#211
5th Gear
The service advisor stated it was the rotors and not the pads. I have had the pads replaced twice and no improvement. The rotors they put on this time have the part number 45251-TJB-A02. They also put on new rear pads as part of the service bulletin. So far, so good.
#212
Brakes on 2019 RDX
I've read a lot of threads on the 2019 RDX brake squealing in cold and wet weather I'm curious as to why nobody finds this as annoying as I do in a brand new high end vehicle is it the fact that the people saying dont worry about it live in a warmer climate to me it has become so bad that I'm questioning whether I made the right move buying this vehicle I always said Acura was the best running car I ever had until now I've tried to get the problem fixed and the dealership claimed there is no fix for it that it's under investigation which I'm sorry there's always a way to fix something anyone else having a concern on this topic please respond ive gone as far as contacting customer relations and still not getting anywhere with that
My sympathy!
I too was was blown off until a service tech took pity and had my front pads replaced. There is still some noise but much less.
is it possible the rear brake pad need replacing too?
So frustrating
#213
Car is in for a b16 service. Mentioned the brake squeal and the service advisor mentioned they already have replacement pads for the RDX. Nothing about rotor replacement. I guess I'll find out this afternoon
#214
ask to replace rotors as well, mine they replaced pads and rotors front and back..
subin (10-02-2019)
#215
#216
Forum Contributor
Received 1,392 Likes
See TSB 19-053 - Front and/or Rear Brakes Squeal When Applied at Low Speeds in the 2019 and 2020 TSB threads.
The following 2 users liked this post by EE4Life:
jonarogers (10-29-2019),
subin (10-30-2019)
#217
#219
2020 rdx
Hello John72:. I have a 2020 with same brake squeling problem. Can you update your post as to whether the new rotors fixed the issue for good?
#221
5th Gear
I have had the new rotors on for 6 weeks and about 1200 miles and so far no squeaks or noise. The previous rotors and pads lasted about 2 weeks. Hope this helps.
#222
Mine is at the dealership now and I just confirmed they are installing the front rotor part number you quoted. As it is a 2020, I would think that new rotor was already on the car but failed to ask that question. It is actually my daughter's new car and she is very disappointed. If this fails to work, I will probably turn to aftermarket ceramic pads although it appears that is only a temporary fix.
jonarogers (11-05-2019)
#225
Your previous post says that you called them to have the rotors replaced on September 30. The updated bulletin with new parts is dated Oct 29... I don't think you got the actual parts. I think you just got replacements of the old faulty squeaky parts. You should go back and get the new parts with the service bulletin in hand.
http://www.urvi.net/forumfiles/SB/B19-053.PDF
#226
Vancouver, Canada
I've had the squeeling front brake problem for 4-5 weeks now. Brought it in for them to check that (and also dead motor for the sunroof) and they just said they are aware of the brake issues but won't get parts for 1-2 months ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Crazy how a brand new car with less than 5,000km within 6 months would have this issue.
#228
Update, I took my rdx in on Nov 5th and they replaced the front brakes and roters under the tsb. It is better. Not 100% but doesn't squeal as loud as it did in cold weather. But still a slight squeal when going slow and lightly pressing brake.
#229
Forum Contributor
The 2020 RDX has been temporarily removed, and will be included in a later revision.
#230
At what point would they refuse to replace the pads because they will say like "user wear" vs an issue with the original brake system they put in?
I am getting this squeal and it is particularly bad because colder weather up here now. I am wondering if I should wait a few months just to make sure everything is working fine for others, etc.
#232
Just got my A-Spec back today and they replaced front and rear rotors and pads under the TSB. No more squealing finally. They also replaced my main harness for the front parking sensors randomly going off. Yea!!!
#233
It's interesting that some have a squealing brake problem, and some don't at all (like me). I wonder what the difference form one car to the other could be that this was a big enough of a problem to create a TSB...for some.
#235
Three week wait for parts
My 19 RDX Tech has been in the shop for a week now to fix the brake noise. They JUST called me today to tell me that the parts are back ordered until 12/1. I’ll have a loaner until then. Unbelievable.
#237
My wife and I just purchased a used (9,800 miles) 2019 Tech RDX last week. This morning she said the brakes were squealing pretty loudly. Granted, we spent the night somewhere, so it was the first time the car sat outside overnight instead of in our garage - the car had some frost buildup on the exterior, so I'm hoping the squealing is simply due to condensation and will not occur when it's parked in the garage overnight.
Just to be clear - the squealing everyone here has been experiencing hasn't been indicative of any major brake issues, correct? The squeal is annoying, yes, but it doesn't bother me TOO much so long as it's not indicative of anything more than an annoying sound.
Also, for those of you who had dealerships replace pads/rotors - did they charge you anything?
#238
There is a TSB to replace pads and rotors to fix the noise, get it done while under warranty
#239
I normally crank up the music while driving so didn't notice the squealing. Noticed it yesterday on my 2020 Tech as I was slowly pulling out of the parking ramp. Seems like it's a widespread issue. Acura should issue a recall
. Going to take it to the dealership to have it fixed/replaced.
