2020 RDX ventilated seat static noise
Looks like I found my first issue with my new 2020. The passenger side seat makes a hissing/static noise when I turn the ventilated seats on. It's quite noticeable and annoying.
The drivers side works perfectly fine with no weird noise. Anyone else with my problem?
On mine, at the highest setting, I hear the fan noise easily. At second setting, not as noticeable, but not as effective (cooling) as the highest setting.
If the noise you are hearing is not the fan noise, then no I don't have this issue.
Passenger seat makes a hissy static noise. Its sound like an electrical short circuit noise. Drivers side sounds fine.
Do you notice this only when the passenger seat is unoccupied? I don't hear it at all if my wife is in the passenger seat, but do hear the hissing if the seat is empty. I just turn off the passenger seat fan in that case.
This is my first car with ventilated seats. What am I suppose to be feeling? I barely feel any air coming out of it. Does it use a separate fan or does it come from the cars a/c unit.
Bingo. The noise goes away when someone sits on it. Problem solved.
Nashua_Night_Hawk
Feb 12, 2002 09:24 AM
