SH-AWD disable?
Old Oct 13, 2025 | 03:51 PM
Djgrippz12's Avatar
SH-AWD disable?
Is there a way to turn off the sh-awd system without damaging the rear differential/transfer case parts
Old Oct 13, 2025 | 03:59 PM
mrgold35's Avatar
mrgold35
Limp mode or disconnect the drive shaft are the only ways I know of disconnecting the sh-awd system. Not 100% sure you still won't damage the sh-awd rear diff if you are towing on all fours with drive shaft disconnected? Do you want to disable for towing behind a vehicle?
Old Oct 13, 2025 | 04:23 PM
Djgrippz12's Avatar
I would like to just see how it handles whilst only the front wheels are powered
Old Oct 13, 2025 | 08:11 PM
NBPDC505's Avatar
Here are some words of wisdom from the best Honda/Acura tuner around (Derek Robinson with IMW) regarding steps to dyno the RDX on a 2wd dyno. You may be able to use these steps to drive with FWD, but I'd be weary as no one is sure if it could cause damage over time.
Old Oct 14, 2025 | 12:12 PM
EasyLoveRDX's Avatar
Unplug one of your wheel speed sensors.
Civic2TSX
May 19, 2019 11:00 PM
Skirmich
1/2G MDX (2001-2013)
Dec 16, 2017 03:32 PM
kar90z
Apr 24, 2015 03:12 PM
TampaRLX-SH
Nov 6, 2007 06:15 PM
Beoshingus
Mar 28, 2006 10:28 AM
