How to remove A pillar driver side
Old May 29, 2019 | 10:59 AM
Yotrek's Avatar
Does anyone can show me how to slightly crack open driver side A-pillar (top) so I can slip in dash cam cable there..TIA
Old May 29, 2019 | 11:15 AM
achong507's Avatar
Check out my post where I linked to some youtube videos that shows you how to do it. It is for an Accord but it is exactly the same for the 2019 RDX. I was nervous but after watching the videos, it gave me more confidence knowing what to look out for. I did it and was very easy.
My post was on March 30.
https://acurazine.com/forums/3g-rdx-...-972555/page2/
Hope this helps.
Old May 29, 2019 | 11:29 AM
Yotrek's Avatar
Hope this helps.
Thanks I'll check it out..things like this make me nervous as well..he he, so you're saying same like Accord the step?
Old May 29, 2019 | 11:47 AM
achong507's Avatar
Yes. Exactly the same as the Accord. Follow the video... very easy.
Old Nov 4, 2019 | 10:54 PM
s1337m's Avatar
I have the tech package which has a speaker inside the A pillar -- how does that change things? I'd also like to run a dashcam wire through my A pillar.
Old Nov 5, 2019 | 04:56 PM
leomio85's Avatar
It's basically the same. There is one extra "green apple" clip and you simply unplug the tweeter by depressing the tab on the bottom of the connector. You may need a screwdriver to depress the tab unless you have skinnier fingers.
joelmatt89
May 3, 2012 07:17 AM
jmw3607
Feb 16, 2012 12:24 AM
integr89
Jun 24, 2005 04:53 PM
