USB some files won't play
I have many files on a usb stick, many play fine, but some do not. The ones that play are mostly .m4a (alaf I think), 128 kbps or 192 kbps. (and file sizes around 4 MB or 6 MB)
Most (if not all) of the ones that do not are also ,m4a but at 600-900 kbps bitrates, and correspondingly larger file sizes (20-30 MB). Is there a limit to either bitrate or file size? and if so, what is the best way to downsize the files? If not, any other reason they will not play? (they do play fine in itunes or VLC on a pc) Thanks.. |
Originally Posted by rdxny
(Post 16301844)
Most (if not all) of the ones that do not are also ,m4a but at 600-900 kbps bitrates, and correspondingly larger file sizes (20-30 MB). Is there a limit to either bitrate or file size? and if so, what is the best way to downsize the files? If not, any other reason they will not play? (they do play fine in itunes or VLC on a pc) Thanks.. I am planning on sending this in as a comment via the Acura owner web site unless there is a better place to register these types of problems without having to take the time to go to the dealer who really end up doing the same thing. |
My biggest issue with USB is the damn high pitched noise and file failure. It seems to be getting worse for me.
There are definitely big holes in this music interface to the car system. The squeals, the misreads, the failure to be able to "back up" in the file structure without going back to the root menu. This is clearly a rushed product portion of the car and they did not do enough testing with it.
The biggest issue is that no one will care if you try and report it. The dealer doesn't care or even understand, the ELS people can't do anything because it's not "their part" that's screwing up, and Acura Customer Service will pretend to listen and just write it off as a "radio problem". We'll see over time if they get their shirt together. |
