Active Noise Control Module
Has anyone disconnected the active noise control module to stop the engine sound from being piped through the sound system? If so, can you post a couple pics or instructions of accessing and unplugging the module? Also, what do you think about the sound system?
search on this site. There is lots of info. Use the search feature.
btw, the high end stereo version is awesome. I did add a sub for more omff, but i switch between the OEM and big sub with a switch. On some music, the rdx sub is just fine.
