Using USB stick with Android Auto ?
I tried plugging in my USB stick to the USB port next to the cupholder and it would not load up while AA was running. Does it have to be off to use it ?
I believe so. Others have posted that USB sticks don't work alongside android auto.
Easiest is to just copy your music from USB to the phone and launch an Android Auto music player. |
I believe that's due to the RDX only having one Data capable USB port. My current vehicle has a USB drive with music in one port and the Android Auto dongle in the other. Switching between the 2 is seamless.
Originally Posted by hand-filer
(Post 16916693)
Originally Posted by SilverJ
(Post 16916694)
I have wireless AA though...my USB stick is in the only data slot by the cupholder.
All the prior complaints were with 2019-2021 with wired Android Auto. Never saw someone try on a 2022 but it would suck if that is an issue too.
You don't have to shutdown AA to switch sources, just press the home button and choose the source, or pick it from the left scroll menu. Then when you return to AA and show navigation, just don't play music and it will be smart enough to keep your other audio source running and only interrupt it for Navigation instructions. Again, don't know if USB works, haven't seen anyone post and try, and on our 22 RDX with wireless AA my wife and I only use streaming music. |
Sadly, it doesn't let us play a USB source while AA is running. Same was true on a Camry rental that we had during the summer. Once AA starts, USB media is no longer available.
(That Camry only had wired AA, but the one data port allowed one to connect a 2-port hub to have access to two different devices through that one port. I tried it with an iPod and a memory stick plugged in to the hub and it was possible to switch between the two. But if the phone running AA was one of the two devices, the other device would not be available.) Real bummer how we get strong-armed into streaming, be it either through the AA source or the satellite radio. I believe that I saw something in the manual shortly after I got the RDX indicating that if a Bluetooth source is connected prior to AA connecting that source would remain available. I have to experiment with that to see whether that is indeed true or if I misunderstood. |
Originally Posted by mvl
(Post 16916946)
You don't have to shutdown AA to switch sources, just press the home button and choose the source, or pick it from the left scroll menu. Then when you return to AA and show navigation, just don't play music and it will be smart enough to keep your other audio source running and only interrupt it for Navigation instructions. Again, don't know if USB works, haven't seen anyone post and try, and on our 22 RDX with wireless AA my wife and I only use streaming music. You probably need 2 data head units like the dual screens from prior Acura generations. |
It really is a shame they don't provide this capability. My 2018 Nissan allowed USB or iPod connection while simultaneously running CarPlay from an iPhone. I sacrificed the FLAC/ALAC capability for the compressed music files on my iPhone. At least it is convenient...and the moving vehicle is far from an ideal acoustic environment anyway :whyme:
Yes, apparently you need to disconnect AA and then hook up the USB. I am going to get a USB extension cable because it is a pain to hook my USB stick into the compartment that the data USB port is located in the center next to the cupholder.
I downloaded the Acura DEMO disc songs in FLAC that another member was nice enough to create and man it does sound amazing. Hopefully AA and USB can work together if the USB is hooked up FIRST and THEN AA is paired up. Honestly, that would be great for me as I would rarely disconnect the USB stick. I wish it worked with another USB port besides the one in the center next to the cup holder. My TL used to have this port (with a extension cable on it too) inside the center compartment, which was much more convenient for something that will be rarely switched out. For those of you who never listened to DTS FLAC music in the TL... you are missing out. It really shows you what the system can do. This stereo has to be one of the best stock units on the market. |
Whether intentional or not, I think it's just a matter of time until Acura kills off the ELS system. The press release for the ZDX says it's the first Acura to get the new B&O sound system and eventually will take over the whole lineup.
Support for MCH FLAC may go the way of the dinosaur but time will tell... |
Originally Posted by ELIN
(Post 16917070)
Support for MCH FLAC may go the way of the dinosaur but time will tell... Like I get the no support for discs...but you really don't need a disc to listen to uncompressed audio |
(Post 16917164)
Why would they kill off support for FLAC ? I would think B&O supports it too.
Like I get the no support for discs...but you really don't need a disc to listen to uncompressed audio Also, you can't use the USB for music at the same time as wireless CP/AA in the 21+ RDX (or any model for that matter), it looks like the processor in the infotainment system can't handle more than one music source. And to someone else's point, I have a 2018 Audi A5 that can run CP/AA concurrent with USB FLAC music being listened to. It is a B&O system, so the quality is less, but at least they can run at the same time. :thumbsup: |
Originally Posted by markm929
(Post 16917218)
I don't think they'll kill off the MCH FLAC support, as other cars with the B&O system support it. That said, the QUALITY of the audio will definitely go down once they switch to the B&O system. The ELS system in Acura cars is one of the best at this price point, in my opinion and will be sadly missed going forward. It may be that the B&O system takes less power to operate, as they are starting use in the ZDX (EV). We may see that going forward with EV cars, other electronics in the cars will lessen in quality as the power draw will have an effect on driving range...until the industry gets the battery figured out.
(Post 16917218)
Also, you can't use the USB for music at the same time as wireless CP/AA in the 21+ RDX (or any model for that matter), it looks like the processor in the infotainment system can't handle more than one music source. And to someone else's point, I have a 2018 Audi A5 that can run CP/AA concurrent with USB FLAC music being listened to. It is a B&O system, so the quality is less, but at least they can run at the same time. :thumbsup: I agree if only one B&O audio system is offered, it will most likely include MCH FLAC support. Otherwise, legacy Acura owners that go all the way back to the DVD-A days have pitchforks in hand! |
(Post 16917218)
OR it may be an additional add on package...like a "entertainment package" or some nonsense..
