USB navigation update
Old Jun 11, 2020 | 04:45 PM
Jauntytime's Avatar
I recently downloaded the most recent file to update via USB. Has anyone tried this? I don’t want to leave the car idling for hours for the rather large file (about 14gb). If I leave in accessory mode, it eventually shuts down to preserve battery.
so far, I’m stuck with a long unnecessary drive....
Old Jun 11, 2020 | 05:52 PM
Waetherman's Avatar
2020 RDX White/Espresso
I think this only takes about 10-15 minutes via USB.
Old Jun 11, 2020 | 05:54 PM
Jauntytime's Avatar
Not for me. I’ve had it downloading for an hour but not complete.
Old Jun 11, 2020 | 05:59 PM
you downloading it to your computer?
Old Jun 11, 2020 | 06:04 PM
Jauntytime's Avatar
Yes, to a USB key.
Old Jun 11, 2020 | 06:13 PM
Waetherman's Avatar
I'm confused; if you're downloading to the USB from a computer, yes that can take a long time. But if you're loading it from the USB to your car, that should only take 10-15 minutes. That's my memory from when I did this many months ago.
Old Jun 11, 2020 | 07:25 PM
Jauntytime's Avatar
I downloaded the navigation update via a Windows computer to the USB key. And it took a considerable amount of time. I’ve been trying to upload it from the USB key to my RDX. That is also taking an extremely long time such that I have been unsuccessful. I’ll have to take an hour long drive and hopefully it updates via that.
Old Jun 11, 2020 | 07:26 PM
maybe you have poor internet connection and a bad USB drive.
Old Jun 12, 2020 | 05:01 PM
Jauntytime's Avatar
I took a drive for over an hour today and at the conclusion of my 1 Hour drive - the database was finally fully loaded. This current issue of the update is a very large file and takes a seriously long time to download FYI.
but - success!
Old Jun 12, 2020 | 05:05 PM
Waetherman's Avatar
Well I'm glad you got it loaded. How new is this update? Is this newer than the one that came in December or whenever it was that I installed mine?
Old Jun 12, 2020 | 05:09 PM
Jauntytime's Avatar
My RDX is a 2020 which I purchased in November last year. The database that was originally installed was dated 2018. The new database I installed is dated 2019.
Old Jun 12, 2020 | 05:28 PM
Wander's Avatar
It might be helpful to note that this is a map and POI database update, not a software update.
It's interesting that you were able to find one and install it, because map updates have appeared and rapidly disappeared several times in the past two years.
Old Jun 14, 2020 | 01:27 PM
NooYawkuh's Avatar
Skeptic
Downloading the update to the thumb drive can take 2-5 hours, depending on your internet connection. But loading it to the car takes less than an hour. Not 10-15 minutes. I've done the update twice.
Best to do it with the car running, like during a long drive. You can still use the navigation and infotainment system while it's loading.
Old Jun 16, 2020 | 10:09 AM
Jauntytime's Avatar
Exactly what I found. Thanks
Old Jun 16, 2020 | 12:24 PM
NooYawkuh's Avatar
Skeptic
Let's review, in case anybody is wondering how to check for map updates.
Go here:
https://acuranavi.navigation.com/home/en_US/AcuraNA/USD
Enter RDX and your car's year. On the next page enter your VIN and the version date of the map currently installed in your car. You'll find it somewhere under Settings but I don't remember the menu path and I'm too lazy to look at the manual right now.
AFAIK, there has only been one update since the 3G RDX has been out. The latest map is "2019.07.08". So, we're coming up on a year since the last update. The previous one was from February 2018. (I think it was "2018.02.28" but not sure.)
Original thread:
https://acurazine.com/forums/third-g...e-live-984201/
Old Jun 16, 2020 | 04:20 PM
EFR's Avatar
EFR
Thanks NooYawkuh....I was starting to get the impression there may have been another Navi update released. I am still surprised that Acura does not inform owners of Navi updates (well, the one or two anyway) and I think that last one was only pretty much discovered by another user poking around on HERE I think.. And...still surprised how many more updates I get (painlessly and flawlessly) on my many-year-old stand-alone Garmin unit in my LR3.
Old May 24, 2021 | 07:53 PM
Addikt's Avatar
@jauntytime, was there any indication that your USB drive was active or being accessed during this time? Mine has a light on it that was dark when plugged into the RDX so I'm not sure if anything is happening.
Old May 25, 2021 | 03:54 PM
NooYawkuh's Avatar
Skeptic
it can take a minute or two for the car to recognize the files on the drive. There's a better and more recent thread on this subject here:
https://acurazine.com/forums/third-g...g-maps-993992/
Old Jun 27, 2021 | 01:19 PM
EMF9's Avatar
So do you just turn the car on, go into maps, and put in the USB drive? I have a fresh 128GB USB 3.0 drive with MSDos FAT32 file system and it doesn't seem to pick it up. Thoughts?
Old Jun 27, 2021 | 01:56 PM
EMF9's Avatar
Update: I have a Samsung 128GB USB 3.0. I tried inserting with the car on and off... and waiting 5 to 10 minutes. Still nothing. The display shows it at least detected a USB drive. But the navigation doesn't do anything. Thoughts? What drive do you all use? I checked and there is a HereMapV1 folder in the root. Still nothing....
Old Jun 27, 2021 | 07:36 PM
NooYawkuh's Avatar
Skeptic
That should work, theoretically. But I think with the first update, it was stipulated to use a 32 Gb USB drive formatted in FAT32. That's what I used then and I still use the same one because I know it works.
Old Jun 28, 2021 | 02:05 PM
EMF9's Avatar
I'll get a 32GB and try it again....
Old Jun 28, 2021 | 08:39 PM
NooYawkuh's Avatar
Skeptic
It may HAVE to be formatted in FAT32, not exFAT. That was the original requirement. I don't know if that's still true for the later updates.
I think you can format a drive larger than 32 Gb in FAT32 but I don't remember how. It may have to be done at the command line. And it may limit the drive to 32 Gb capacity.
Either way, don't re-download the update. You can just copy it to your computer and restore it later without losing its integrity. I've done a map update from a backup.
ETA:
Try this on your USB.
https://www.howtogeek.com/316977/how-to-format-usb-drives-larger-than-32gb-with-fat32-on-windows/amp/
Old Jul 2, 2021 | 12:11 PM
EMF9's Avatar
ETA:
https://www.howtogeek.com/316977/how...n-windows/amp/
I think we are getting there. Got a 32gb formatted in fat32. Now it says updating map.... But ... That messages disappears and I have just been sitting in the car for like 20 minutes waiting for something to happen. A progress bar would be useful here....
If I navigate around in the maps it will randomly pop the updating bar back up.... But no complete or anything like that.
I guess I just keep waiting. This process really isn't the best
Old Jul 2, 2021 | 12:49 PM
NooYawkuh's Avatar
Skeptic
It takes about an hour. I've heard of it taking as long as 1:20.
BTW, there is a new update released just a few days ago. I hope that's what you're loading.
https://acurazine.com/forums/third-generation-rdx-2019-454/map-update-991165/page3/#post16732896
Old Jul 2, 2021 | 01:12 PM
EMF9's Avatar
https://acurazine.com/forums/third-g.../#post16732896
Holy smokes.... Do I just leave the car running on my driveway?
Old Jul 2, 2021 | 11:11 PM
NooYawkuh's Avatar
Skeptic
You can leave it I accessory mode (not ON) and it won't drain the battery. I usually leave map updates for when I expect to be driving for more than an hour. I'm in no hurry to do map updates. The roads don't move much from one update to the next.
Old Jul 3, 2021 | 07:44 AM
JB in AZ's Avatar
In the two + years I owned the '19 RDX I never updated that Navigation maps. I used it once or twice early on and decided it was so bad, it wasn't worth my time. Google maps is so much better (My connection issues with AA not withstanding)
Old Jul 3, 2021 | 01:08 PM
Seafood Licorice's Avatar
Question about the map update process: If you start it but turn off the car, does the file upload resume the next time you turn on the motor or start over?
Old Jul 3, 2021 | 01:44 PM
Waetherman's Avatar
It does.
I swear I don't remember it taking more than an hour, but I guess it's possible. The last time I did it I just plugged it in on the way to the grocery store, about a half hour drive. Got there, forgot I was doing it, shut the car off. Midway on the drive home it told me it was done.
Old Jul 4, 2021 | 12:57 AM
sonyfever's Avatar
The process would start from scratch.
Old Jul 4, 2021 | 09:28 AM
rdevillers's Avatar
I powered up the car in “Accessory” mode (engine not running) and plugged in the USB drive. The update took just under an hour.
Old Jul 11, 2021 | 12:03 PM
dweilbacher's Avatar
Updated my Map a few day ago to the latest version: 2021.03.18. Verified the version was correct after restarting the RDX.
This morning I got a message that my MAP is out of date. Odd. But checking the Nav Update site, 2021.03.18 is still the latest.
Old Jul 11, 2021 | 03:28 PM
Jejo's Avatar
Same exact thing happened to me today and I just updated mine yesterday.
Old Jul 11, 2021 | 05:07 PM
kboo74656's Avatar
Updated mine yesterday and entered a destination and no map out of date message. Map version is correct. Update took about an hour.
Old Jul 11, 2021 | 05:33 PM
Ron T's Avatar
There is a second discussion regarding this issue (here).
Someone indicated it is related to the "Connected" feature of the navigation in that same thread (here).
Ron
Old Jul 13, 2021 | 03:33 AM
Jerzy's Avatar
Same happened to me. It doesn't resume installing in Accessory mode (I tried 3 times), but it does in Power/Drive mode. It doesn't make any sense.
Old Jul 16, 2021 | 02:43 PM
comanche250's Avatar
What port do you use to upload to vehicle?
Old Jul 16, 2021 | 03:06 PM
NooYawkuh's Avatar
Skeptic
The only one you can use is inside the console. That's the only one that connects to the infotainement system. All the others in the car are for charging only.
Old Jul 16, 2021 | 04:25 PM
Jerzy's Avatar
Of course I used the one in the console.
