Unlocking passenger door?
Old Dec 17, 2019 | 07:18 PM
Bmosbacker's Avatar
Ok, I admit this is probably a dumb question but humility is a virtue, so here goes. :-)
I can’t figure out how to open the passenger door when I unlock the driver’s door using the sensor on the driver’s handle. The simple scenario is my wife and I walk out to the car. I unlock/open the driver’s door with the door handle but the passenger door does not unlock. I tried using the back door handle on the drivers side but that does not open the passenger door either. So, I unlock my door from the outside and then use the inside lock button to unlock the passenger door for my wife. How can I get both the driver’s door AND passenger door to unlock at the same time without using the remote? What am I missing?
Old Dec 17, 2019 | 07:21 PM
Jfkmk's Avatar
Unlocking both doors is one of the system settings. As an aside, touching the back door on my RDX unlocks both sides. Of course, you’re supposed to go around and open the door for your wife!
Old Dec 17, 2019 | 07:25 PM
Bmosbacker's Avatar
Thanks—and your right about opening the door for my wife. Is that still permissible in today’s culture? :-)
Old Dec 17, 2019 | 08:38 PM
Madd Dog's Avatar
For the wife? That is between you and her. I open the door for my wife. I also hold the door open for a person behind me, regardless of gender. When possible, I open the door for a woman. None of them have ever given me the stink-eye for doing that.
That’s how my mother raised me.
Old Dec 18, 2019 | 12:47 PM
Bmosbacker's Avatar
Thanks but just for the record, my comments was "tongue in cheek." :-)
Old Dec 18, 2019 | 05:07 PM
NooYawkuh's Avatar
Skeptic
When I touch the driver's door handle, only the driver's door unlocks. When I touch any other door handle, they all unlock. If there's a system setting for it, I've never changed it.
Old Dec 19, 2019 | 07:11 AM
Josh32121's Avatar
Yeah, there's a setting in the infotainment system to have all doors unlock all the time instead of the driver's door first. I have that option selected, and no matter which door I touch when walking up, all of the doors unlock. Maybe that's your solution. Or maybe if you touch the driver's door twice it will unlock all doors like the default setting on most remotes (?).
Old Dec 19, 2019 | 10:33 AM
JDMaccord3.5's Avatar
Unless you have a base model, only the front doors will open when you approach handle.
Old Dec 19, 2019 | 10:50 AM
Waetherman's Avatar
2020 RDX White/Espresso
con5tant
Oct 28, 2023 09:08 PM
00TL-P3.2
Sep 8, 2015 08:47 AM
hzm82
Mar 16, 2003 12:29 AM
