Transmission Oil Filter for Acura RDX 2020
Do we really need to replace "Transmission Oil Filter" when changing transmission oil for Acura RDX 2020? I asked the mechanic in the dealer they said they don't really change the filter when change transmission oil. However, I watched a video on YouTube, that guy changed the filter too
Considering Honda/Acura's notoriety for transmission failures in the past, I would be inclined to inspect the filter and replace as needed. If your trans fluid interval is at 30K, i'd probably look to replace it every other change (~60K interval) because it's cheap insurance. https://www.oemacuraparts.com/oem-pa...ItMGwtbDQtZ2Fz
I mean it's only 23 bucks so why not
attofarad (10-07-2022)
I don't see a service manual there, just owner's manual and nav manual.
It is not necessary to inspect and/or replace the ATF filter as part of routine maintenance. Just make sure to follow the maintenance minder and use the recommended fluid as listed in the owner's manual.
ErikDuong
3G RDX (2019+)
09-30-2022 12:00 PM
