Timing belt / chain
Old Apr 30, 2025 | 02:50 PM
vvraman's Avatar
Timing belt / chain
How often are you changing timing belt (or is it chain)? Does the maintenance minder know when to replace it?
Old Apr 30, 2025 | 03:34 PM
russianDude's Avatar
Its a chain, it has no set maintenance and supposed to be lifetime unless you have issues
Old May 4, 2025 | 11:50 AM
sonyfever's Avatar
You don't need to think about replacing the timing chain until you get close to 200k. In general, people view it as a lifetime component, unless you abuse the engine way beyond the norm.
Timing chain itself has proven to be one of the most reliable components on K-series engine over 20 years. Usually, it is the tensioner that shows sign of wears first.
Old May 4, 2025 | 12:17 PM
Nobody replaces timing chains as preventative maintenance unless there is an issue (sound and etc), even if you have 300k miles.
Old May 4, 2025 | 12:56 PM
sonyfever's Avatar
Yeah, I remember I replaced the chain once (not on RDX, of course) just because the tensioner needed replacing and the cover was already taken off.
Old May 5, 2025 | 11:28 AM
Believe it or not, but more frequent oil changes will help preventing excessive chain wear
Old May 5, 2025 | 01:52 PM
roaBf's Avatar
Talking
So, my 2025 RDX has a timing chain; all this time I thought it had a timing belt. What a relief!
Old May 5, 2025 | 02:16 PM
SilverJ's Avatar
that saves you about $1500 worth of maintenance RDX is awesome !
Old May 5, 2025 | 05:23 PM
roaBf's Avatar
Talking
This is the best news I have had all day!!!
Old May 5, 2025 | 08:39 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
How does that work?? Dirty oil puts more pressure on the cam??
Old May 5, 2025 | 09:56 PM
metal to metal contact oiling reduces wear, also not sure if tensioner for chain could be operated by oil pressure
api GF-6 has special test on chain wear. There is a lot of info on chain wear and importance of oil maintenance
Old May 30, 2025 | 11:57 AM
MattB16Teg's Avatar
^ Good point there!
Worth nothing, Chains normally aren't the issue, you have to worry about tensioner(K series issue) and guides failing too. But Chain is still way better than OG timing Belt although belt is way easier to replace.
Vannertoo
1G RL (1996-2004)
Oct 10, 2017 09:14 AM
HockyStar89
Apr 3, 2007 07:49 AM
dougal813
1G TL (1996-1998)
Mar 13, 2004 01:06 PM
